different catalytic converter
Old Jan 17, 2005 | 01:23 PM
Chapman88SR5's Avatar
will a cat from a smaller engine size (1.8L) cause any problems or cause a worse performance on my 22re?
Old Jan 17, 2005 | 03:14 PM
to be specific the catalytic converter is from an integra gsr, a guy from school thought id want it so he brought it to school.
Old Jan 17, 2005 | 04:01 PM
wvuviv30's Avatar
what size is the inlet?
Old Jan 17, 2005 | 04:04 PM
2.25"
Old Jan 17, 2005 | 06:07 PM
the_supernerd's Avatar
2.25" is too large for a stock 22RE, but you can probably have a muffler shop put reducers on each side. I am not sure what that would do for you performance, but it probably would not lower it.
Old Jan 17, 2005 | 08:38 PM
Keggo's Avatar
I'm not sure how accurate this is, but, if it's smaller it might not have the correct capacity to successfully catch all the toxic gases. Correct me if I'm wrong. How strict are the IL smog checks?
Old Jan 17, 2005 | 09:08 PM
This particular cat is actually bigger than stock. It should catch all of the toxic gases as long as it is in good shape. If you install it, you might want to go ahead and upgrade the rest of the cat back exhaust to 2.25" with a free flowing muffler. 2.25" is suppose to be the maximum size for the 22RE without lowering your low end torque.
Old Jan 18, 2005 | 04:17 AM
i planned on it but i thought 2" was for the 22re and 2.25" for the 3.slow?
Old Jan 18, 2005 | 12:39 PM
You will have to measure, but the 22R has 1.75" pipe. I believe the 3.0 has 2". Check out this website for more information:
http://www.walkerexhaust.com/VehicleTypeScrn.asp
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
