Diff breather size
Old Nov 21, 2003 | 06:43 AM
NVRSASTK's Avatar
Diff breather size
Has anyone ever used a 3/8" male brass niple in place of the toyota part? If I run a tap through first will a 3/8 nipple work? I ask because I read an article about using a 1/4 " npt nipple and I assumed it was a 1/4" nipple with the standard 1/2" thread....Guess what way to large .
I guess I'm asking will a 3/8" Dia thread into the old breather hole?
Thanks Chris
Old Nov 21, 2003 | 06:50 AM
waskillywabbit's Avatar
Re: Diff breather size
Thanks Chris
Are you looking to extend your rear diff breather?
Old Nov 21, 2003 | 06:53 AM
NVRSASTK's Avatar
breathers
Yes, Toyota doesn't have the parts and I had read somewhere that a guy used npt threads and just ran a tap in the hole first
Old Nov 21, 2003 | 06:55 AM
Re: breathers
Read these two links and it should give you what you need.
http://128.226.93.56/ and go to write-ups, rear diff breather ext
http://www.wattora.com/mods/diffbreather/
These should give you what you need and desire!
Old Nov 21, 2003 | 07:05 AM
NVRSASTK's Avatar
Didn't answer
They used the Toyota part I don't have the toyota part.
Old Nov 21, 2003 | 07:07 AM
Re: Didn't answer
The two Toyota parts cost maybe $10 from the dealer and work perfectly.
Old Nov 21, 2003 | 07:11 AM
NVRSASTK's Avatar
Problem
I talked to my toyota dealer over 3 weeks ago and he said the parts were on back order. I have already waited 3 weeks and now he says it going to be 2-4 more weeks. Has anyone ever used this application before with a 3/8" npt nipple
Old Nov 21, 2003 | 07:14 AM
Re: Problem
Sorry I can't be of more help, but it sounds like your dealer is "blowing smoke up your skirt." I order parts at my dealer on one day and in two days my parts are there. I can't imagine why two little standard fittings like those would be on back-order. I bet TOR could check for you and get them to you cheap.
Old Nov 21, 2003 | 07:18 AM
NVRSASTK's Avatar
Thanks for trying though
I guess I'm going to try this 3/8" size nipple....Hope it works. I will let you know Chris
Old Nov 21, 2003 | 07:28 AM
Arnold's Avatar
I'm going to have to agree w/ wabbit. Either your dealer is too lazy or don't know WTF they're doing. You could probably even find the fittings at a local junkyard.
Old Nov 21, 2003 | 07:30 AM
PoBoy's Avatar
Re: Thanks for trying though
It works...I did it. Only costs 50 cents. Much cheaper than the dealer.
Old Nov 21, 2003 | 07:51 AM
Flygtenstein's Avatar
I bet 1/8" NPT would work better.
Old Nov 21, 2003 | 07:58 AM
NVRSASTK's Avatar
Fitting
I found that a 10mm fine thread air fitting screws right in. 1.24 each
Old Nov 21, 2003 | 08:03 AM
PoBoy's Avatar
Naw, just take a 3/8 bit and drill the hell out of it. Works fine...
But yeah, 1/8 is what I used I guess...its been a while. Here is Roger's Writeup on using the NPT fittings that I followed. http://4crawler.cruiserpages.com/4x4...html#Breathers
Old Nov 21, 2003 | 08:20 AM
I have 1/8" fittings too.
I got two nipples and an elbow for less than 3 bucks. Home Depot, Napa, Lowe's, any place that sells anything automotive or plumbing ought to have a big bin of them.
Old Nov 21, 2003 | 08:38 AM
Robinhood150's Avatar
I just tore off the cap from the original breather, shoved a tube over it and hose clamped it in place. Seems to work.
Old Nov 21, 2003 | 10:40 AM
keisur's Avatar
Re: Problem
My dealer didn't carry them either and I had to order them from www.1sttoyotaparts.com .
Old Dec 1, 2003 | 03:59 PM
LarsDennert's Avatar
You can also get the parts from a Nissan Dealer. http://www.larsdennert.com/4runner/breather
Old Dec 1, 2003 | 09:44 PM
toy283's Avatar
I had a pile of Autometer metric adapter fittings. Two of them worked just fine to adapt from 10mm to 1/8 NPT.
Old Dec 1, 2003 | 10:26 PM
jx94148's Avatar
I cringe every time I hear about people tapping the breather hole. I hope the hardened steel shavings find the magnetic drain plug before they chew up the gears too much.
I used a Nissan one up front and the Toyota part in back. If I had it to do over i'd save the $16 I spent and do it like Steve's (Robinhood150) suggestion for more like $3.
