Deck Plate Mod Question
Old Aug 19, 2003 | 01:18 PM
coolerthanice's Avatar
When you remove and replace the EFI fuse while the motor is off--does this really reset it even thought the motor is off?
Old Aug 19, 2003 | 01:22 PM
TDiddy's Avatar
Yes.
Leave it out for a good 15-30 minutes. Jacksonpt's write up says to pull the fuse when you start the mod, then just put it back in when you're done.
Old Aug 19, 2003 | 01:58 PM
rimpainter.com's Avatar
Allegedly this will allow your ECU to "learn" the increased airflow faster than if you just drove it. Either way, it will adjust accordingly.
This is a debatable practice as many do not think it does anything.
Hard to say. I just do it cause its easy.
Old Aug 19, 2003 | 02:01 PM
TDiddy's Avatar
Let me clarify:
I got a Check Engine light as soon as I started up after doing the deckplate mod. Pulling the fuse reset the light for me. It may or may not have an effect on resetting the air/fuel control, etc. Pulling the fuse when you start will save you from possibly having to do it for a CE light.
colasurdo
Jan 11, 2026 08:10 AM
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Massmayhem247
Jul 18, 2015 05:46 AM
