Deck Plate Mod Completed!!!
Old May 22, 2003 | 09:43 AM
Plamar's Avatar
I just completed the deck plate mod. The toughest part, as everyone has pointed out, is cutting the hole with a Dremel. It made a hell of a mess, and a very non-uniform circle. I used a shop vac afterwards to get everything out. I pulled the 20 amp fuse before I started.
I got the deck plate for $7.00 from a local marine, the sensor safe sealant for $1.99 for a small tube (more than enough), $.84 for the six screws. $9.83 for this mod was not a bad deal, if you have all the tools already, and some average skills.
I was not able to put the screen on the back side with the clamp. The waffle material made it so I could not get the screen and clamp on. Is the screen a necessity, or more of a "nice to have it"? It doesn't look like it would get much in there by way of large debris or bugs or anything due to the placement of the hole ( it faces the headlight and washer filler tube).
I took a quick spin down the street, and noticed the "roar" doesn't kick in until you get the RPMs goin (which is what I have read). I will post more once I have a chance to get her up to cruisin speed!
Old May 22, 2003 | 09:53 AM
ssbogger's Avatar
I didnt haven dremel handy so i used a jig saw. If you take your time cutting the hole (about 5 mins) then a jigsaw works perfectly. I didnt put the screen on mine either and i probably wont. If i see any large bugs in there i will just clean them out. The air filter will catch them.
Old May 22, 2003 | 10:05 AM
rimpainter.com's Avatar
I never put a screen on either of my deckplates. I personally dont think its necessary. Its just a preference thing.
If you have an air filter, the screen is pointless. My opinion of course.
Old May 22, 2003 | 10:14 AM
CLin9383's Avatar
the screen is just for bugs and leafs..i have found bugs and leaves in my engine but not near the intake..i haven't seen anything stuck on mine or anything...so it doesn't really matter..
SLC Punk's Avatar
I agree with Christian, I don't think its necessary because it is behind the headlight
Old May 22, 2003 | 10:45 AM
Alstaz's Avatar
I did my Deckplate last night too, and I also found that the Dremel was a bit of a pain. I was able to put the screen on and secured it with a large Zip Tie. To me it is just the little bit of added insurance.
I did my mod in conjunction with the silencer removal mod. There is definitely an added roar, and a noticible increase in acceleration. I seem to have gained back all that I lost by going to the bigger 285/75/16 Revos. Now I gotta learn not to step on it to hear the roar!
Yee Ha!:bounce2:
Old May 22, 2003 | 11:00 AM
I hope everyone is using the circle-cut attachment for the dremel, it makes it a whole lot easier!
Old May 22, 2003 | 11:04 AM
Plamar's Avatar
[QUOTE]Originally posted by <96 Runner>
[B]I hope everyone is using the circle-cut attachment for the dremel, it makes it a whole lot easier!
Yes, I bought that today..it made it easier, but not easy. It wanted to skip around a bit on me. You also need really good light to see the circle you drew to cut out the hole.
Old May 22, 2003 | 11:11 AM
Alstaz's Avatar
I had the adapter as well. I am glad I didn't have to try it free hand.
Old May 22, 2003 | 11:12 AM
Bob_98SR5's Avatar
96,
I helped my buddy perform the deckplate this weekend and we used the tools you used too. It helps but for future reference, you really need to do two things:
1) stabilize the air box either in a workbench (like a B&D workbench) or have someone else hold it.
2) grip the dremel really hard. The bit will jump/skip when it hits the internal waffle ribs inside.
Better yet, suck it up and buy the appropriate sized hole saw for your drill.
Bob
Old May 22, 2003 | 11:26 AM
TDiddy's Avatar
Bob
Yes, if only I would have had gone and picked up a hole saw bit, I would have skipped all the same headaches that have been already mentioned!
Old May 22, 2003 | 11:27 AM
Bob-
Yeah, those are good pointers to future deckplaters out there. I always cut the hole a little smaller, then used coarse sanding bits get the extra size I needed. Of course, I am a big man with my 6" deckplate compared to all you 4 inchers.
Old May 22, 2003 | 05:05 PM
obxfishn's Avatar
This sounds like a great idea. I am still tossing the idea around.
Old May 22, 2003 | 06:11 PM
AznSky's Avatar
Actually the hardest part for me was getting the lower bolts out, probably because we didn't have an extension for the sockets haha. Oh also sanding the edge of the hole just so the deckplate fits perfectly. Cuz I cuz the hole small on purpose to make sure I had the tightest fit.
Old May 22, 2003 | 11:54 PM
Tacoma Dude's Avatar
So what is a sensor safe sealant?
Would regular silicone sealant/adhesive work?
Old May 23, 2003 | 05:05 AM
jalaber's Avatar
Sensor-Safe Silicon Sealant, Permatex #598B UltraBlack Hi-Temp
The screen in definetly not necessary as the filter will pick up the junk, but it is nice to have it.
Old May 23, 2003 | 08:55 AM
AznSky's Avatar
You can pick it up at autozone or checker for like 3 bucks for the little tube, which is all you will need.
Old May 23, 2003 | 09:16 AM
Cool!
Just wanted to see if my current tube would be okay.
Thanks fellas
88sasturbotoy
Jan 30, 2026 01:57 PM
bigjstang
Jun 2, 2025 03:56 PM
theking11863
Mar 19, 2016 09:36 PM
TDonkey
Jul 26, 2015 10:14 AM
Massmayhem247
Jul 18, 2015 05:46 AM
