deck plate mod about to be done. some small questions about tools
You can do this whenever... it only takes maybe an hour from start to finish. Be sure to pull the EFI fuse when you start and put it back when you're done to reset your computer.
This should help you along...
https://www.yotatech.com/forums/show...deckplate+fuse
this is going to sound stupid but where is the EFI fuse?
got all the screws out for the box and need to disconnect that before i go further.
and can someone circle the maf sensor as well before I pull something out that doesnt need to be takin out
EFI fuse (on my 2000's) is the middle 20A fuse (small ones) on the bottom of the fuse block. There should be a diagram on the cover. The fuse block looking from the grille is on the drivers side just past the battery. Easiest access is from the drivers side. Stand on drivers side and look at the battery, move right and you will see the fuse block. As you look at the block the fuse is in the middle row on the bottom (closest to you). There should even be a tool to remove and replace on the inside of the cover.
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
