Dash Light install....HELP!!!.
Old Jan 3, 2008 | 01:07 PM
GOH10 Runner's Avatar
Well first I ordered all new red LED Dash Lights from Autolumination.com. In that order I had three Type A Neo-wedge bulbs that go in the ECT, Rear Defog, and A/C Switch, received....not one works. Why would those bulbs not work in ANY of the switched I had.
Issue two is I tried to take apart my gauge cluster to find out how many bulbs to use, and in order to find it out it looks like I have to disconnect the rear of the cluster. If i unplug the cluster will it screw up my gauges or can i unplug it anytime.
Issue Three and the most important. When i was taking off the part around the gauge cluster I tried to move it around cause the dimmer switch didn't want to unhook. I felt a little pop and found a wire going to the security system light became detached....it looks like a small black wire with two prong like things on the end. My question is can I hook the wire back up...if not will I still be able to use my keyless entry or will my car even start.
Old Jan 3, 2008 | 01:18 PM
Fo_SheeZy's Avatar
For the dash lights, they should work. You just have to correctly line them up so the ground connects. And for the gauge cluster the only problem I had when I unplugged mine was two things lit up. VSC TRAC and VSC OFF, I think?
Old Jan 3, 2008 | 01:20 PM
i tried every neo-wedge in every place more than once.....none worked.
Old Jan 3, 2008 | 01:22 PM
Fo_SheeZy's Avatar
That's odd, the same thing happened with my stock bulbs, When I took them out to measure, I couldn't get them to work once I put them back in...
Old Jan 3, 2008 | 01:25 PM
maybe they are really sensitive, i might of beat them up trying to screw them in.
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
