Custom radio install in 2003 4runner (pics)
Old Mar 18, 2003 | 10:06 AM
impulsebrklyn's Avatar
Well i got the head unit in a few days just got a chance to post some pics. I made the installtion kit myself with some mdf, sand paper, black spray paint and alot of time. I used the factory head unit brackets to fasten the kit. The radio is an alpine cda-7897.
There are pictures of the back but that is just temporary for the next month. The three amps will be attached behind the seat with a large ported box on the upper deck of the cargo area.
Old Mar 18, 2003 | 10:19 AM
Good Times's Avatar
looks good
way better than mine! hehe... and mine has the aftermarket insert too!!
You should look into putting the amp in the side compartment! I think you can fit a 8" for sure in there but maybe a 10" ...
just some ideas!
but looks nice anyway
Lance
Old Mar 18, 2003 | 10:36 AM
yeah the back is a work in progress, I just wanna get the new speakers in the doors and get the amps connected then im gonna redesign the back. Chris
Old Mar 18, 2003 | 10:51 AM
pfdaxe's Avatar
Looks good and I'm sure sounds even better. But 1 question(of course):
Why didn't you install a double-din head unit to fill the factory stereo location??
Old Mar 18, 2003 | 10:55 AM
Los Gatos?'s Avatar
Is that a Brahma in the back? If so then I'm sure that thing pounds. I love that head unit, I was looking at them but opted for a much cheaper touchscreen unit. What kind of front speakers do you have?? I see you have 2 amos...
Old Mar 18, 2003 | 11:20 AM
yes it is a brahma but im having trouble with the current setup not proper box nor direction Im finding. Im in debug stage. I acctually have three amps the 3 rd isnt in the the tantrum isnt even connected to anything yet. I will be running a pair of image dyanmic chameleons componets with 125 watts, and then a pair of mbquarts of something in the rear feeding them 60 watts with another tantrum.
Old Mar 18, 2003 | 11:31 AM
no double din cause off of the good head units arent double din!!!!
Old Mar 18, 2003 | 12:31 PM
Outkast`'s Avatar
Thumbs up Tight
Nice set up!!!
Are you adding any other aesthetic enhancements (neons, fiberglass, clear speaker box)? Anything that you add will only make a tight azz system tighter.
Outkast`
Old Mar 18, 2003 | 01:54 PM
Doublepump's Avatar
Looks Great! I am thinking of that same head unit. They just have so many different models I can't decide. I would prefer a non face off, and that one fits the bill.
Old Mar 18, 2003 | 02:38 PM
yes it is a non face off which is great it goes and hides itself atomatically its great.
Um not sure there will be a few neons it the back, with some neon fans. Im in the process of designing a new box cause I cant face the sub up, it just doesnt work. It needs to be faced at the rear window for good output. So a new box and a second brahma is in need. And a different amp i think i need more power at 2 ohm.
Chris
Old Mar 18, 2003 | 03:14 PM
A+'s Avatar
A+
bk- does the power antenna go up only when u listen to the radio or does it go up all the time you press power?
Old Mar 18, 2003 | 03:20 PM
Woodbert's Avatar
Chris,
That is sweet!!
Old Mar 18, 2003 | 03:46 PM
jharris2's Avatar
'03 antenna is in the rear glass. There's not an external antenna.
Old Mar 18, 2003 | 04:17 PM
Vrooooom's Avatar
can you still control the volume and the stations from the steering wheel?
Old Mar 18, 2003 | 04:20 PM
Good Times's Avatar
very doubtful on the controlling the vol etc etc on an aftermarket radio.. Unless you hardwire it in (which I have no idea...)
Old Mar 18, 2003 | 04:22 PM
it can be done and will be one of my future mods its very easy to do all you have to do is purchase this item and install it. They got about 60 bucks. But im not sure if its worth it for my my head unit does have a remote control.
http://www.go2pac.com/products/swi.htm
PART# SWI-X
Old Mar 18, 2003 | 04:25 PM
BT17R's Avatar
Chris, awesome job, better leave the rear window down when it's cranked!
Another question, sorry. The flip out mini-bin below the climate controls, can that be pulled and the space good for something else like a CB, or is it too shallow? Thanks.
Old Mar 18, 2003 | 04:35 PM
Good Times's Avatar
BT17R:
That slot is too narrow for a cb but it might work.. as for me, I'm planning to wire up a power inverter somewhere there so I have extra power slots...
who knows.... just thinking of some cool ideas
Old Mar 18, 2003 | 07:23 PM
yes there is not much room there. also the piece you are refering to is attached to the main center console trim. It would require alittle extra modifiction. Chris
Old Mar 25, 2004 | 11:01 AM
Goosenheimer's Avatar
Hey Chris,
I put in a panasonic unit at Thanksgiving and have been meaning to wire the SWI-X for some time. Did you install it yourself? I couldn't find the wire the instructions refer to because that part of the installation was done by a shop and they cut off the factory harness. I need to know which wire I want to attach to the SWI-X input as well as whether or not I need to use any of the supplied resistors.
Thanks,
Erik
