coolant leaking from radiator trans lines, 98 4runner
Old Aug 21, 2016 | 02:34 PM
chicago60647's Avatar
I dropped the skid plate on my '98 4runner for an unrelated reason and saw some green coolant dripping from the hose on the bottom passenger corner of the radiator where the hose meets the radiator.
I thought, no problem, I'll go get a new hose. I pull the hose and see pink fluid drain from the line and realize it's transmission fluid. No green coolant came out the radiator, however.
What the hell is going on!? Why is green coolant dripping from the trans line? The car runs perfectly fine.
Old Aug 21, 2016 | 03:06 PM
ThorInc's Avatar
Google: Pink Milkshake 4Runner
Hopefully that's not it but the trans fluid circulates through the rad for cooling. Add a trans cooler and that will avoid the "Pink Milkshake", when trans fluid mixes with coolant.
Old Aug 21, 2016 | 03:22 PM
Thanks for the response, ThorInc.
I am googling pink milkshake, and I guess that has to be it. However, my coolant overflow is green and the transmission dipstick looks normal, not milky. Transmission behaves normally. A little problem shifting from reverse, but it has 320K on it, so I think that's just wear and tear.
So I think maybe I have a really small leak and just got lucky? Either way I guess I need a new radiator.
Old Aug 21, 2016 | 03:25 PM
ThorInc's Avatar
If there is no mixing, awesome. Stop the leak and add a trans cooler, flush the rad and change the trans fluid while you are at it. I may not be the pink milkshake but this is a great time to make sure you never do.
Old Aug 21, 2016 | 03:34 PM
Thanks for the advice, I think I'll do just that
Old Aug 21, 2016 | 04:33 PM
Marc's Avatar
Maybe the leak is somewhere else and just flowing down the hose.
If you removed the hose and antifreeze didn't come out then it can't really be coming from the hose.
Old Aug 21, 2016 | 11:23 PM
wyoming9's Avatar
I can`t work on cooling systems without a pressure tester makes finding small leaks easy most of the time .
Coolant leaking and dripping down on the cooler line.
Old Aug 23, 2016 | 12:14 PM
So I dried everything up and waited a day to see what exactly was leaking from where. From the pic below you can see that the nipple for the trans line is dripping red transmission fluid. But the nut that is holding the nipple is dripping green coolant! Not sure what to make of it. Any thoughts?
Old Aug 23, 2016 | 12:18 PM
millball's Avatar
U needa new radiator.
Plastic/aluminum ones are not reliabily repairable.
Old Aug 23, 2016 | 12:27 PM
Marc's Avatar
The nipple is dripping (not leaking) transmission fluid because that's what goes through the bottom part of the rad.
It's dripping because you took the hose off. If the rads leaking then you should change it.
I'd do it soon in case it does leak into the transmission cooler part.
Old Aug 23, 2016 | 12:29 PM
Right on. Will be replacing the radiator. Thanks
Old Aug 23, 2016 | 01:47 PM
fierohink's Avatar
In the pic you can see the far right most three crimps are damp and darker. Your rad is leaking somewhere above and coolant is collecting at that fitting as the lowest point.
If your trans dipstick is still clean and red, I don't believe you are suffering a milkshake. More than likely just an old rad that needs to be replaced.
NerfHerder-97SR5-
16
May 9, 2003 10:21 AM
trdtacoma01
Sep 13, 2002 12:21 PM
madone
12
Sep 1, 2002 09:54 AM
HaveBlue
Aug 5, 2002 01:42 PM
UKMyers
10
Jun 14, 2002 12:42 PM
