converting a Previa to 4wd?
I have never heard of anyone asking that question. But I can say this, there are people who have asked if they can change their Celica to all-wheel drive. It is possible but very very hard. I know for the toyota all-tracs (corolla, camry and celica) they have different floor boards and the fuel tank is in a different location. You would need to find a doner Previa to convert all the parts over, but if you go through that much work you are better off selling the Previa you have now and get a All-Trac Previa. My $0.02
Originally Posted by bluefever
it's an automatic and it's two wheel drive,don't know much else about it
I'd say if you can't muster that info then you won't be doing the job yourself. That being the case, I'd guess converting to 4WD with a low range transfer case will run you well over the value of the vehicle. Don't bother.
I see an All Trac Previa in your sig. What's wrong with that one?
[I gues my question is would the transfer case from a 4runner,taco,or land cruiser bolt up to the automatic 2wd transmission and what else would need to be changed?}
Nope, if you want a 4x4 offroad caplable Previa (and I think it would be cool too!) then you need everything, the entire drive train.
[what would you have to change to put in an fj80 transfer case?]
Everything. The entire drive train. And a chassis.
There is a simple (relatively) solution. Find a donor 4x4 pickup, probably an Xtra Cab long bed. Use the entire frame, lengthened or shortened to match the wheelbase of the Previa. The Previa has no frame – there is nothing sturdy enough to attach the front end to, or attach motor mounts and trans crossmembers too for that matter. You’ll need to lose the mid-engine layout, so you’d have to cut up the floorpan to get a transmission hump. Etc. It could be done, but I can assure you that from the basic questions you asked it’s probably not something you’re really gonna do. Every single step will be custom, from body mounts to suspension to connecting up steering and brakes,and wiring etc… and you need to know what you’re doing up front to be able to make it all work, especially if you want something safe, driveable, and cool when you’re done.
From: Grew up in Santa Clarita/San Fernando Valley's...now in Washington State
Originally Posted by kevin444
I second this!
Toyota's most ugliest cars ever.
1. Previa
2. Echo
3. 99 corolla
4. all the rav4's
1. Previa
2. Echo
3. 99 corolla
4. all the rav4's
