Conic Filter on Tacoma - Impossible?!
Old Oct 22, 2003 | 05:44 PM
SpLiZaaT's Avatar
...It seems to be!!! I have a 1996 2.7L tacoma and I'm trying to just remove the POS airbox and throw a Conic filter in it's place...
Sound easy enough but the Mass Air Flow sensor is connected into the piping that connects directly into the airbox and has a SQUARE fitting that bolts onto the side of the airbox, instead of a pipe, THUS making a bolt-on mod a bit more complicated.
I have been looking around because I don't want to buy an entire intake kit, I simply want to throw a K&N conic filter in place of the airbox and call it good. I just checked ebay and found the following listing: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2438924605
You will notice that the filters are both ˟˟˟˟, but my eye is on that adapter!!! That will allow me to bolt into the mass air flow piping then put a conic filter right on there, but i am not about to spend 40 bucks for just that adapter so I can throw away the crappy filter! I am wondering if anyone has any links to buy JUST the adapters?! Or an idea for me to use without replacing the pipe.
A deckplate and filter are still in the picture, but I think a conic would work better?
Old Oct 22, 2003 | 06:05 PM
its2slo's Avatar
do this and get a good k&n cone to put on the end of the pipe you have fabbed. that foam looks like poo, just my opinion of coarse....
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
Old Oct 22, 2003 | 06:08 PM
SpLiZaaT's Avatar
No no..the filter in that auction are ˟˟˟˟ - i know that!
I am pointing out the design of the adapter in the top left. THAT is the piece i need so i can throw a conic k&n and rock and roll...
Old Oct 22, 2003 | 06:16 PM
its2slo's Avatar
should be able to add some supports to the pipe if you do it that way, i was thinking wire coat hangar would work great with the dryer vent pipe mock up....
Old Oct 22, 2003 | 06:30 PM
SpLiZaaT's Avatar
hrm...i am not sure i'd feel safe with dryer venting as my air intake hahaha... I NEED to find an adapter!
Old Oct 22, 2003 | 06:50 PM
its2slo's Avatar
keep your box and do the deckplate mod, elbow mod, and then do the isr.
some pics of the deckplate:https://www.yotatech.com/forums/show...ghlight=intake
Old Oct 23, 2003 | 02:57 AM
mattk's Avatar
Hey dude I have a '95 Tacoma with the 2.7 and made the adapter myself for about $5. Ill try and take a pic of it tonight after work and post it on here. All I did was took a piece of heavier gauge sheet metal and a 2.5" or 3"(cant rememeber but will check) PVC Terminal adapter for the cone filter to clamp to. Works great! Let me get you a pic and see if you can fab one yourself. Any other questions just ask. Give me a day to get you a pic before you go buy an adapter.
Old Oct 23, 2003 | 01:29 PM
SpLiZaaT's Avatar
Pics would be VERY appreciated! I don't even know where to buy the adapter, so i think i may have to make one anyways.
Old Oct 28, 2003 | 02:48 AM
mattk's Avatar
Sorry dude about not getting you a pic of my adapter yet! I have uploaded this stupid photo a hundred times and it still wont show up. If you can give me your email ill try and send it directly to you and see if it comes up that way. And again sorry but let me know.
Old Oct 28, 2003 | 05:54 AM
SpLiZaaT's Avatar
no problem. Email it to splizaat@twistedmods.com
smthwsn357
May 1, 2024 07:28 AM
polo451
13
Nov 20, 2016 07:49 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Toyvana
Jul 29, 2015 10:47 PM
jjrbus
Jul 23, 2015 05:05 PM
