cold air intake
Old Feb 27, 2004 | 12:37 PM
slammdrider's Avatar
cold air intake
i have an 84 toyota pickup with a 2.4 efi 22re motor and i want cold air intake but cant find one does anyone know of one i can buy or know a way i can make one.
Old Feb 27, 2004 | 12:49 PM
cubuff4runner's Avatar
There are a few things you can do. K&N makes a cone filter intake which costs a lot of money $200-$300, considering it is just a filter and a piece of metal to mount the filter onto the sensor. Try looking on e-bay and sometimes you can find the same set-up as K&N. Use the metal mounting assembly and buy a better filter. This will ussually cost $75-$150. I am not 100% sure how your setup is but many of the 22re's have the intake running over the radiator heating the air. You can switch the battery with the air intake so you have only a few inches to the intake manifold from the sensor instead of a few feet.
Old Feb 27, 2004 | 01:06 PM
rimpainter.com's Avatar
Personally, I would get an adapter for the MAF. It will bolt up via the 4 screws. Then, I would run piping into the fender where I would have a cone K&N filter with the largest possible surface area. I did this on our Accord, and I gained just as much HP as my friend with a $230 intake. I saved $185.
Old Feb 27, 2004 | 01:42 PM
The adapter is what I was talking about from e-bay. The filter was in the fender? How would you get to it? Doesn't it get dirtier there?
Old Feb 27, 2004 | 01:48 PM
so on ebay i shold look for a mass air flow sensor adpter for an 84 toyota pickup or what
Old Feb 27, 2004 | 01:58 PM
rollandfayssoux's Avatar
downey off road makes an intake for the toyota
Old Feb 27, 2004 | 01:59 PM
tenfourtyeight's Avatar
Try the seller 'fcdtuning.' I'll be getting one from them.
Old Feb 27, 2004 | 02:17 PM
does downey have a website and if so what is it
Old Feb 27, 2004 | 02:25 PM
downeyoff-road.com
Old Feb 27, 2004 | 02:33 PM
chuckd's Avatar
On gadgets site didn't he try one of those k&n kits or something and it turn out no better than just an amsoil filter? Perhaps I should check.
Old Feb 27, 2004 | 03:11 PM
They don't help out to much. The only reason I did it was to move the intake to the other side where it did add power.
Old Feb 27, 2004 | 03:42 PM
On the 4Runner, the K&N "sucked" (no pun intended). What I am talking about is a MAFS adapter, yes. From there, you relocate the actual intake of the air to a fender. Yes, you greatly increase the chance of water injestion and possible exposure to greater amounts of particulates. However, as far as bang for your buck, a cold air intake cant be beat. I assume you do most if not all of your driving on the street. Otherwise I would reconsider my idea. I will admit, on a lot of engines K&N cone set ups work really well. Why people spend $200+ I have no idea. You can easilly make an intake that is just as effective.
Old Feb 27, 2004 | 04:13 PM
on the downeyoff-road site the only one near my truck is the one for a efi engine but its for 85 to 87 would that fit or no
Old Feb 27, 2004 | 04:20 PM
You are asking if a 22RE adapter will fit on a 22R? I would say no. You are carbed right?
Old Feb 27, 2004 | 04:26 PM
ianshoots's Avatar
Believe he found that it was no better (or slightly worse) than using an amsoil filter in conjunction with the elbow removal/decplate mod. Of course he's working on the inate for a '98, things may be a little differnent between the two trucks....
Old Feb 27, 2004 | 04:42 PM
no my engine is efi and the downey is a cold air intake for efi engines but its for 85 to 87 i want to know if it will still fit on a 84
Old Feb 27, 2004 | 05:15 PM
Call downey and see what they say. There could be differences that would make fitment impossible.
Old Feb 27, 2004 | 07:51 PM
aviator's Avatar
Arrow
Check with downey but I think the only difference was in the design of the valve cover on the engine. I don't recall any other differences on my old truck and friends older trucks eighties hiluxes. aviator
Old Feb 27, 2004 | 07:56 PM
As long as the air sensors were the same you will be OK. If you have access to any fab. equipment you can always make one. All they are is a flat square piece of metal with holes for bolts on each corner, with a round metal 3", I believe, piece that comes out. 30- 1 hr. project with the right equipment.
Old Feb 29, 2004 | 06:40 PM
now im not sure but i dont think your truck came factory with efi. 1985 and later trucks only came with efi, that is why downey says 1985-1987. you can write down your VIN number and check what engine it came with to be sure. www.4x4wire.com has a section under FAQ that explain the VIN number. or you can write down your engine number (im not sure where its at) and bring it to a dealer and ask them what year your engine is.
