clutch troubles...
Old Jan 31, 2003 | 05:58 PM
rowan's Avatar
Unhappy clutch troubles...
my clutch started acting really wierd today all of a sudden. i dont think its giving out completely because all of a sudden it just started letting out really roughly. its only starting out, not switching gears... i dont really know what it is im hoping it will just go away. so if anyone has any ideas let me know.. i can give some more info if you need too. thanks.
Old Feb 1, 2003 | 12:11 PM
rowan's Avatar
well nobody's said anything so here's a few more details...
i can get it to start out smoothly but its hard i have to have the gas just right, and usually it'll start to shake before i get the clutch all the way out. i was comin home today and was shifting into 4th.... i had the clutch all the way in, and it was just making a grinding sound. went back into 3rd no problem, and when i went to ˟˟˟˟ up again it was fine. i've got my 30,000 mile tune-up coming up soon so hopefully they'll fix it then.
one more thing... what do i need to do for the 30,000 mile tune up. do i just take it in to the dealer and they'll do it??
thanks a lot..!
Old Feb 1, 2003 | 12:17 PM
Corey's Avatar
Co-Founder/Administrator
Rowan, I have driven sticks all my life up until late '98 when I got the Runner.
It sounds like a glazed clutch assembly to me.
The grinding could also be the throw out bearing.
I only had to have a clutch replaced once in my life, and that was my first car I got back in '75, a '68 Chevelle.
We had a stock one put back in.
If you replace yours, stock is probably best, unless you get the right aftermarket one.
Many report problems after going with an aftermarket one.
Old Feb 1, 2003 | 12:27 PM
CTB's Avatar
CTB
As far as 30,000 mile tune up goes:
-oil & filter change
-replace differential(s) oil
-replace t-case oil
-replace tranny fluid
-replace spark plugs
-new air filter
-rotate tires and balance
..maybe a few other things, but that is a good start. By the way, almost all of this stuff you can do yourself - no need to pay the dealer.
Old Feb 1, 2003 | 01:06 PM
Shane's Avatar
Clutch chatter is what that's commonly called, usually due to irregular wear or hard spots on the flywheel or pressure plate.
Not sure from your description on the grinding but it might be your throwout bearing starting to wear out. When/if you get the clutch replaced make sure they also replace both the throwout and pilot bearings, surface the flywheel and replace the pressure plate. The pilot bearing is the one that's pressed into the end of the crankshaft and hels support the transmission input shaft.
Stock is a safe bet on the clutch, Marlin's set gets good reviews. Centerforce and most other aftermarket ones get mixed reviews.
Old Feb 1, 2003 | 03:33 PM
mogwai snot's Avatar
If it's only grinding when you go in 4th gear than most likely your 4th gear synchronizers are going out or possibly your shifter forks. Time for a tranny rebuild!
Old Feb 1, 2003 | 03:41 PM
azrain's Avatar
Duct tape it!!!! I like Red Green too...
Of course I'm kidding here. Shane brings up a good point in a clutch install that a lot of folks ignore for some reason. Grinding, or turning the flywheel contact surface. It's really important to the life of the new clutch AND to determine if the flywheel surface has "hard spotted".
It sure sounds like a clutch problem from the description.
Mike
Old Feb 1, 2003 | 06:34 PM
rowan's Avatar
well it only did it into 4th gear once... today it seems to be a little bit better. i'll probably take it to the dealership where i bought it and have them do all that stuff...except for the oil.
corey, whats a glazed clutch?
thanks for all other feedback too!
Old Feb 3, 2003 | 05:26 PM
Victor's Avatar
According to Downey any clutch over 1500 lbs is a waste due to Toyota's slave cylinder design (if I recall right). Marlin has a 1200 and a 1600 lb clutch kit. Anyone tried them? Since I do lots of city driving I'd like a stock or close to stock pedal but obviously I'd like a stronger than stock clutch since I plan to do more wheeling and my truck will probably be getting a lot heavier as I add mods.
Old Feb 4, 2003 | 02:20 PM
Mudd Runna's Avatar
Where in Maine?
Hey Rowan...where abouts in Maine are you?
Old Feb 4, 2003 | 03:27 PM
rowan's Avatar
cool, someone from else from maine. ill private message you.
as far as the clutch goes, it's definatly getting better.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
