Clutch Holding instead of Ebrake
Old Mar 30, 2010 | 07:18 AM
Toyoda22's Avatar
Not your typical argument thread on what better and which to use.. Ha if i used just my clutch my truck would be destroyed anyways..
So I'm outside waiting in my truck for my friend to get some money to buy a keg and I'm parked on a pretty slight incline maybe 10 degrees tops. I turn off the engine and put it in first and just let it sit. It stays put for about 10 seconds then i feel a little jerk backwards. 5 seconds later another little slip of the clutch. each time i'm maybe moving backwards a few inches but is this normal, i dont think so? do i need to adjust something? enlighten me
this is the first time i've witnessed this in my truck. i dont think my clutch is going out because I put the e-brake on and let the clutch up in 1st and it stalled out plain and simple.
Old Mar 30, 2010 | 07:21 AM
Lumpy's Avatar
Are you sure you were in 1st sitting there? Sounds like the motor turning a bit and not the clutch slipping.
99% of the time I use my e-brake and then but it in gear. I do the same with auto as well. Hold the brake, apply the e and put it in park. Keeps the weight of the car off the trans...
Old Mar 30, 2010 | 07:31 AM
Toyoda22's Avatar
I was definitely in first. its a standard. I didnt even think that the motor could have been turning over a little bit. didnt realize that would happen.
Old Mar 30, 2010 | 07:56 AM
Lumpy's Avatar
There have been times I thought I was in 1st and was in 3rd and the motor would turn a time or two on a slight incline. I have also had it happen in 1st but it was quite a steep hill.
Old Mar 30, 2010 | 08:05 AM
Toyoda22's Avatar
now that i think about it, it must have been the motor turning over a little because when i went to start it i barely had to turn the key and it fired up faster than ever
Old Apr 1, 2010 | 01:38 PM
wyoming9's Avatar
Red face
Hi mileage worn engine
Yes the vehicle will move on a hill like that .
Williamemslie
14
Oct 5, 2015 09:28 AM
viesail
Sep 5, 2015 04:23 AM
Squigglez
Sep 4, 2015 07:33 AM
Nick Berg
Sep 3, 2015 04:36 AM
Ryall
Sep 2, 2015 06:48 AM
