Which clutch is a better one?
Which clutch is the better one?
Ok my choices are:
JT outfitters clutch $115 I believe they use stock aisin parts
LUK clutch I can get from a parts store they have in stock locally for $167
Which clutch would you buy?
How much do OEM clutches cost from a reputable on-line dealer?
I guess I could see how much I can get one from www.conicellitoyota.com ,I got my OEM springs there for $200 which is $160 cheaper than the local stealership wanted.
My clutches for my Eclipse cost about $400 +install and those only lasted 3 years or less so anything is better to me.
There certainly isn't anything wrong with the stock clutch. They do a fine job in these vehicles. I don't recognize the name LUK, so I would be a bit shy of that one. Between the two, I therefore would be inclined to go with the stock one from JT, if it is indeed a stock clutch.
Have a Zoom clutch in one truck, and a Centerforce in the other. Both have worked very well.
when i bought my 4runner, it had a Luk clutch in it, and I was not allthat thrilled with its performance. It drove around town just fine, but tended to smoke up during heavy offroading. when it finally gave out in Hollister Hills, and I replaced it with a stock clutch, it was easy to see that the stock clutch was much more heavy duty than the Luk.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
