Clay Bar uses
Originally Posted by obxfishn
Has anyone had any experience using the Clay Bar. Does anyone have any positive/negative feedbacks about the Clay Bar to achieve a "new vehicle shine"?
I think there is a detail and polish forum on here somewhere. The "after" pics I have seen were great!
DANG! Corey was 2 minutes faster!
Originally Posted by Corey
See my website for the Detail Section, or via my sig file here.
Many posts on the forum about clay bar also if you input it into the search field.
Claying is easy for me. I clay both rigs twice each year then polish and wax. I clay by hand first using a spray bottle with water and a few drips of dish soap to break the surface tension then just run the claybar over the rig top to bottom, takes five minutes is all.
Works great every time, that paint is smooth as a baby's butt.
Mick
Mick
I think claying a vehicle is the easiest and cheapest way to achieve that smooth finish, personally I don't think it makes a big difference in appearence, but if you're obsessed like me, then you want a perfectly smooth surface.
I clay using Meguairs quick detailer, hand wax with Zymol cleaner wax, and go over the finish with a micro fiber towel with quick detailer again. My truck is black, and the resutls are amazing.
But I do need to buy a rotary buffer and start getting better products for my clients cars.
www.autopia.org
Once again, if any of you like to keep your rig as clean as me (and a handful of other members here) you should join autopia and learn, learn, learn. I thought I knew just about everything about detailing, until I started reading on that site. I felt like a rookie that didn't know anything.
www.autopia.org
I thought claying was a gimick for years, until I finally tried it. I don't understand why it does what it does, but it sure does it well. It doesn't give a magic shine, it removes all the rough sticky stuff. The paint becomes silky smooth after claying. It's easy to do and doesn't take long. I clayed my wifes entire station wagon for the first time in about an hour. Subsequent clayings would take less time.
Originally Posted by waskillywabbit
Clay, why use clay? Using clay is stupid. Claying is a complete waste of time and makes your vehicle's paint look like crap!
It doesn't taste very good.
On a positive note, though, I found that plastalina modeling clay found at most craft stores is nearly identical in composition to the clay in Meguiar's and Mother's kit. And about 1/5th the price.
