Checking rear brakes on 2nd Gen
Old May 21, 2003 | 12:41 PM
Paul H.'s Avatar
I wanted to check how my rear brakes were doing so I pull out the little rubber piece on the back side to inspect them. The problem is that I really don't know what I am looking at. Can someone either descibe what part is the brake shoe or show a picture. Thanks for the help.
Old May 21, 2003 | 07:16 PM
NCSU-4runner's Avatar
if im thinking what you are describing thats the bleed valve, try taking it off again and have someone press the brakes, you should get a nice stream of brake fluid come out. thats how you get any air out if you do brake work.
ohh yea, dont forget to top off your brake fluid resevoir under the hood if you do that
Old May 22, 2003 | 01:37 AM
UKMyers's Avatar
Don't bleed your brakes for no reason at all! You need someone to help you and you can mess up your brakes badly. I believe he is talking about checking the thickness of the pads. The easiest was to do this properly is to pull off your wheel, remove the drum and look at them that way. The drum may be hard to get off, especially if you haven't had them off for a while. You'll be amazed at how much crap builds up in there since there's no where for brake dust and mud to go. Mine worked alot better after I cleaned them all up thoroughly.
Old May 22, 2003 | 05:39 PM
Victor's Avatar
there are 2 12mm screw holes to help you pull it off. If you insert bolts in there and tighten down it will push the drum off for you.
Aleeex_u
Jun 5, 2016 06:52 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
cchinny
Jun 25, 2015 08:11 PM
Dr. Evil
Jun 12, 2002 07:32 AM
