Check Engine on,vsc,tsc off
no
Ive had all those lights on but I dont think ever at the same time so id sayi dont think its that common. Give it a couple of days mine sometimes comes on when i go wheelin then goes off after a couple of days
Yep. Lots of faults can bring up all those lights. There are a lot of things that can take ABS out, for example, and with no ABS, you have no traction control or VSC. Best thing to do is get the codes pulled (some places do it for free, like autozone). You can't diagnose a problem with the lights alone.
I got code: P1135 Manufactured controlled fuel and air metering
Does this mean I need a new mass air sensor or can it be cleaned?
All I have on the 4runner is the amsoil air filter.
Nope... code P1135 refers to bad heating circuit in your A/F sensor (which for a cali spec truck is the O2 sensor in front of the catalytic converters)... Otherwise known as bank #1 - Sensor #1.
It is not a code for your MAF.
The code comes in to signal that the current in the heater circuit of your A/F sensor is either too high or too low. Try troubleshooting the sensor itself or there may be a short in the sensor wiring.
I bought the o2 sensor from toyota for a whopping $230 and put it on. I reset the computer and the lights are now off.
I checked olympus import parts too, and they sold the sensor for $250 so I don't feel like I got ripped too bad. Would have been nice to know someone and get an employee discount, but oh well.
I wasn't sure that "bank 1 sensor 1" was the o2 sensor before the cat, but I googled it and found a write-up with pics. liquid wrench is your friend!
Thanks for the help GSGALLANT!
Simple things
... for anyone else following this thread.
Two minor issues that can cause the engine check light, VSC Trac, and VSC Trac Off lights to turn on:
1) loose gas cap - yep, I was surprized as well, but the dealer checked my cap and sure enough it was loose. Lights turned off a few days later... which they also said was normal.
2) low brake fluid. Makes sense since this is a braking system.
Okay, I got the same here. The lights on the dash and the code was the same. But this happened right after I installed a new radio. I know the ABS has some equipment in the dash behind the ash tray. Hey, there is very little room in this truck (the Japanese utilize every little space).
I had the code pulled, then erased and was good to go for one day. Then it came back. All this from just brushing up against a wire in the dash?
p1135
I just got that on my 2002 4runner
Regarding this issue, I have a 2001 4runner, also with the P1135 code (Air/Fuel sensor bank 1/sensor 1).
Can anyone tell me or show me a photo of where this is located? My Haynes manual doesn't seem to give any indication.
Thanks in advance!
Thanks in advance!
I crawled under the truck to see if I could make it out. Coming down at the backside of the engine I saw this:
I believe this is one of the Air/fuel sensors but I'm not entirely sure if it's the one I need to change out. I'm guessing that the cat in the foreground?
