Check Engine light @ 75k miles
Old Sep 26, 2004 | 04:46 PM
Poke Runner's Avatar
Does the check engine light automatically come on @ 75k miles? Does it do this to get you to take it to the dealership to get the 75k maintenance?
I found the list of codes to run the self diagnostic, that's my next step.
Everything seems to be running smoothly.
thanks
Old Sep 26, 2004 | 04:50 PM
Gadget's Avatar
No, it is telling you something is wrong. The check engine light means you should get the engine control system checked and repaired.
Gadget
Old Sep 26, 2004 | 04:54 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I see that you have an Amsoil air filter. $10 says that your MAF needs cleaning. It's pretty simple. You'll find writeups in the Tech section for the 3rd gens.
Bob_98SR5's Avatar
betcha its your front 02 sensor
bob
Old Sep 26, 2004 | 05:28 PM
"I see that you have an Amsoil air filter. $10 says that your MAF needs cleaning. It's pretty simple. You'll find writeups in the Tech section for the 3rd gens."
That makes sense. I think I've had the AMSOIL filter in for a while and its due for a cleaning.
thanks
Old Sep 26, 2004 | 07:27 PM
halza's Avatar
o2 sensors need to be replaced most likely, don't go to the dealer they'll rape you, I just did mine a few months ago when my toy hit the 100k, it was the 02 sensor.
Old Sep 26, 2004 | 07:46 PM
kevin444's Avatar
When i bought my 2000 4runner sr5 it haf 104k miles. The seller told me the check engine light and got that fixed. I told him what was wrong and he said something o sensor. SO well thats good enough to me that he's saying oxygen sensor!.
Old Sep 26, 2004 | 07:53 PM
SloPoke's Avatar
It could be something as simple as your gas cap gasket, an o2 sensor, your cat. conveter pluggin' up, the the big vac. line into the air box isn't connected or is pinched, ect. ect. ect.
Gadget is right. You should get it checked.
Old Sep 26, 2004 | 08:03 PM
SpecializedBrder's Avatar
Is there such a thing as catalytic converter cleaner? because mine is definietly clogged or not working right and my engine is throwing a code for it and getting it cut off is gonna be a pain.
Old Sep 26, 2004 | 08:31 PM
SloPoke's Avatar
You sure your code is the cat and not the o2 sensor?
Your cat is flanged so it's just a simple unbolt and bolt replacment. Why's that goina be a pain?
Old Sep 26, 2004 | 08:49 PM
X-AWDriver's Avatar
Convertors don't get clogged with "stuff" so to speak,when they are "clogged" it usually means the ceramic material has broken apart or in cases of running high exhaust gas temps then the material can actually be melted. Replacements are usually under $100.
Old Sep 26, 2004 | 09:03 PM
My 3rd gen 2.7 has the catalytic converter welded to the downpipe
Old Sep 26, 2004 | 09:48 PM
kevin444's Avatar
please buy my LC headers and High Flow Cat
That will take kare the problem. Ill throw in a e10 torx socket!
Old Sep 27, 2004 | 04:51 AM
MTL_4runner's Avatar
bob
I'd bet money you're right.
Only way to know for sure is to pull the actual code number and post it when you get it.
Old Sep 27, 2004 | 02:31 PM
SloPoke's Avatar
How much you need to get for your LCE header and hi flow cat?
Would you seperate? I NEED a hi flow cat but would only LIKE a header.
Old Sep 27, 2004 | 02:33 PM
SloPoke's Avatar
It came stock welded up?
Old Sep 27, 2004 | 08:53 PM
After work I stopped by Autozone to get the diagnostic run. They do it for free. I was a little pressed for time, it only took 5 minutes.
The code that came up was P0120 which is the Throttle Position Sensor/Switch. A circuit malfunction from what the guy told me.
What does this mean?
Is this something that can create a domino affect to other parts?
They have the part for $79.99. Where does this thing go anyways? Besides my ace if it will include lots of labor.
But the weird thing was that the check engine light turned off when I left the parking lot. Did it do that because the diagnostic was run?
Thoughts?
Old Sep 28, 2004 | 04:32 AM
Thoughts?
That is a pretty rare code for the 4runner but yes, that does indicate a bad TPS (I would get it from the dealer instead tho).
See the link to all the codes here:
https://www.yotatech.com/forums/show...ighlight=P0120
No, you shouldn't see any domino effect except maybe bad gas mileage.
It goes right on the top of the engine, very easy to get to and replace.
You can see it (black part) attached to the left of the throttle body in this pic:
Usually when they finish pulling the code they also clear it so if the part is still bad you will see the CEL come back on to signal that the problem has not been fixed and if you pulled it again you would see the same code again.
Old Sep 4, 2005 | 09:16 PM
RuffRider's Avatar
Did you end up purchasing this part from the dealership? I was curious what one of these cost...
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
