Chasing my tail here. Misfire on 2/4/6 after t-belt replacement.
Old Feb 20, 2013 | 02:15 PM
stophammertime's Avatar
Hey all. Recently replaced my t-belt, v-cover gaskets, cam seals, PCV valve, intake plenum gaskets (both mid and lower), etc. The basics while doing that job. Double and triple checked timing, it's spot on. The issue I'm having which I cannot track down is that the Runner starts up fine, runs and idles fine when cold, but after it reaches operating temp, I throw a CEL for misfire on 2/4/6, it idles like crap, and very low (about 600-700 rpm, very boggy), with a sulfuric smell (assuming my cat is getting hot from running lean or something). Any ideas?
'96 T4R SR5
I'm just stumped. I tried the carb cleaner trick to try and hunt down a vacuum leak, but came up empty handed. Thanks.
p.s. Sorry for the single post count. Long time lurker. Appreciate the loads of info, and sweet rigs around here.
Old Feb 20, 2013 | 04:52 PM
250000_yota's Avatar
I know you stated it, but I'd check the belt timing. Also make sure you didn't knock the cam sensor or bend/dent/damage the crank sensor tone ring right behind the crank pulley. I've seen them run fine at idle and then because of a slight bit of damage to that tone ring.
Also, one my little brother saw at work, was a 3.4 that broke its woodruff key on the crankshaft. He pulled the upper cover and found the cams dead on, but when he pulled the bottom apart, he found the crank pulley had jumped 3-4 teeth, allowing it to run, but really badly...
Old Feb 20, 2013 | 05:12 PM
rworegon's Avatar
Also, check the locating pin on the cam that holds the cam gear in position.
live4soccer7
May 11, 2016 06:52 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
the_supernerd
Oct 1, 2015 09:20 PM
Draven023
11
Oct 1, 2015 06:47 PM
Scotttekoch
Sep 28, 2015 10:30 PM
