Changed brakes now no brake power
Old Mar 2, 2013 | 09:26 PM
blackout138's Avatar
I just changed my front brakes on the passenger side. While I was taking off the caliper, I loosened a bolt which had some brake fluid spill out. I tightened it as quickly as possible and then reassembled the brakes. Now I have no brake power. Did I destroy my brakes buy loosening the wrong bolt? Is this the reason for no power?
Btw, I have a 99 4runner 3.4L, 4wd.
Thanks.
Old Mar 3, 2013 | 04:14 AM
DRCOFFEE's Avatar
You let air in the line. If it works its way to the ABS or master, you need specialized equipt to rebleed the system. Try bleeding the brakes.
Old Mar 3, 2013 | 04:23 AM
Darryl01088's Avatar
Sounds like you opened the bleeder screw. You will have to bleed the brakes. You can buy a mighty vac http://www.mityvac.com/pages/products_hvpo.asp at most auto parts stores. Otherwise you will need two people. Suggest you consider taking the car somewhere and having the brake system flushed. Bleeding brakes is simple but it could take you hours if you are unfamiliar with the task.
Old Mar 3, 2013 | 04:29 AM
DRCOFFEE's Avatar
This is a safety issue. It needs to be done correctly.
Old Mar 3, 2013 | 06:35 AM
5runner's Avatar
yes take it some were! specially if you dont even know what you loosened! it is a rather important system on the truck!
Old Mar 3, 2013 | 06:42 AM
KZN185W's Avatar
you need to bleed your brake system to remove the air that went in when you opened the bolt.. and btw, it's a 3.4L not a 3.6L.
Old Mar 3, 2013 | 07:59 AM
Thanks.
Ok thanks. I've been looking for a good write up but can't seem to find one. I found one here. How does it sound?
Old Mar 3, 2013 | 08:01 AM
What kind of safety issue? Thanks.
Thanks everyone for your replies.
Old Mar 3, 2013 | 08:21 AM
KZN185W's Avatar
That should do it.
<img id="ums_img_tooltip" class="UMSRatingIcon">
Old Mar 3, 2013 | 08:33 AM
rworegon's Avatar
Seriously?? How hard is it to figure out that lack of braking i.e stopping is a serious safety issue?
Old Mar 3, 2013 | 08:40 AM
I thought you were talking about during the bleeding process, not the after effects.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
