Catalytic converter ?'s
Old Mar 23, 2004 | 01:21 PM
AmPm's Avatar
Ok, so I got a new muffler this weekend, the Dynomax Superturbo. I instantly noticed a couple of things. First that it really did improve the acceleration from off the line to highway cruising (It's not CBR 600 RR, but that's not what i want in a truck anyway) and second that there is this horrible rattling when I give it the gas, that I've narrowed to the Catalytic Converter.
You would think that the guy at the muffler shop would have said something, but whatever. I need a new CC and I've been looking around here and I have narrowed it to a high-flow CC (probably dynomax) but here are my questions that I couldn't answer:
Do I have an O2 sensor on the CC?
What size intake and output pipes do I have? (I'm pretty sure it's 2.25 out)
Are the universal CC's one size fits all?
Thanks,
Adam
Old Mar 23, 2004 | 01:32 PM
AmPm's Avatar
I forgot to mention that it's a 92 4runner 3.0L 2WD..sorry
Old Mar 23, 2004 | 02:15 PM
Churnd's Avatar
Your 02 sensor is right before the cat.
Your pipe diameter should be 2" in and out, unless it's been changed.
Just find a converter that has a 2" inlet and outlet and have it welded on.
Are you dead set on a dynomax? I could be wrong, but when I was looking, the only reason for getting a dynomax is for the bling bling chrome look. If you wanna save some money, get a CarSound. They're high flow, as are any and every aftermarket replacement catalytic converter.
Old Mar 23, 2004 | 07:29 PM
rimpainter.com's Avatar
Are you positive the cat is bad?
Old Mar 24, 2004 | 08:41 AM
AmPm's Avatar
Thanks, for all your help guys. I'm not positive its the CC, but I talked to the guy who sold me the 4runner and he said it has never been changed. So I figure that it probably needs it anyway.
So, I found this CC on ebay, do you think it will work? I emailed the seller, but no responce...http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468263218
Old Mar 24, 2004 | 11:41 AM
Fink's Avatar
I'm running that muffler as well and I love it...
AgRunner06 is runnin the same muffler and has a high-flow cat on his and I think he likes it...PM him and see what he says.
Good luck,
Fink
Old Mar 24, 2004 | 04:59 PM
AmPm's Avatar
Ok, I found out that the pipe on either side of the CC is 7.5 inches...by my ruff calculations that's about 2.25 inches in diameter (inside the pipe)...right? It's been a long time since I needed to figure this stuff out. Anyway...I found some on Ebay for around $60 shipped.
Now, if it isn't the right size, can the muffler shop do anything like narrow the pipes?
Thanks
Adam
Old Mar 24, 2004 | 05:09 PM
They can, but it wont be optimal. If you are going to replace the cat, you need to know the exact size. It will just work better that way.
I vote for a Carsound cat.
Old Mar 24, 2004 | 05:36 PM
Churnd's Avatar
Are you sure about the diameter? I might be wrong but I thought Toyota didn't offer any pipes over 2". Other than that, the cat you picked out looks good.
When you get it, look through it and then look through the one you had on it. You'll be amazed.
Old Mar 24, 2004 | 05:41 PM
Fink's Avatar
Yeah the piping is 2", I put a 2.25" tip on it though...it just took a lot more welding.
Fink
Old Mar 25, 2004 | 03:48 AM
AmPm's Avatar
Ok, I'll crawl under her again and look. The pipe might be tapered off before it goes into the cat.
Just a curiosity question...what's that piece of sheet metal that is right above the cat? It's only attached to the left (driver) side? It's about an 8th of an inch thick; I can't imagine what it might be for...
Old Mar 25, 2004 | 05:01 AM
You mean the heat shield? It prevents the floorboard from melting.
Old Mar 25, 2004 | 05:12 AM
AmPm's Avatar
It's a pretty flemsy heat sheild, then, I wonder why it's only connected to one side.
Old Mar 25, 2004 | 05:53 AM
PirateFins's Avatar
Heat shields do not have to be thick. If it was thick it would be a heatsink. The heat shield is 1/8" thick so it doesn't absorb and retain the heat, airflow around the heatshield disapates the heat. It is only attached to one side to allow for expansion when it heats up. Basic properties of metals, you need some way for the metal to grow (and it does) when it gets hot. Did I loose you yet?
Old Mar 25, 2004 | 06:51 AM
AmPm's Avatar
I think you lost me right after "heat"...LOL
It makes sense, when you put it that way.
Thanks
Old Mar 26, 2004 | 12:50 PM
carose725's Avatar
just order a dynomax highflow cat from summit racing. i just put a dynomax super turbo muffler and the dynomax cat with all 2 1/4" piping. sounds great and the high flow cat is only $55 from summit, and their shipping is free i think. you wont be dissapointed.
Old Mar 27, 2004 | 05:05 AM
AmPm's Avatar
I just ordered a carsound from ebay for $45 and $10 shipping. I got the 2" in and out. I love the muffler! And now I have something to put in my signature..woohoo
Old Mar 27, 2004 | 06:25 AM
growinseed's Avatar
the heat sheild is the source of you rattle. the heat shield is spot welded on it should be attached at the four corners,at the flat tabs on the cat. I cured this rattle by drilling pilot holes then using four short #8 sheet metal screws. Guess this reply is a little late since you already bought a new cat.
Old Mar 27, 2004 | 06:36 AM
AmPm's Avatar
That's ok, I think I'm going to need it sooner or later anyway. Thanks for your reply I'll ask the guy who installs the CC to take a look at it and maybe tack it on for me.
Adam
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
