Cat questions
Old Jul 3, 2004 | 12:35 PM
88yotaboy's Avatar
Cat questions
How important is it to have a good cat on the truck? Right now im running a hollow cat with a flowmaster muffler and 2" pipe from the cat back. Is it important for me to replace the cat? In my area smogging it isnt and issue unless i sell. The guy at the muffler shop said i dont have to worry about since i dont drive over 65(no freeway round here).
Thanks for any advice,
Andy
Old Jul 3, 2004 | 04:07 PM
jimbo74's Avatar
it will hurt your vehicle performance.. no matter what anyone says, it was designed to reduce greehouse gases and NOX and HC and other stuff... it is harmful to the environment, if you have EFI, it will screw up the codes as most run with an O2 sensor and it will goof that all up too.... physically it isnt going to hurt the truck, but running dirty is jsut not a good thing....
Old Jul 3, 2004 | 06:08 PM
88yotaboy's Avatar
What is the best type of cat to get?
Old Jul 3, 2004 | 06:57 PM
jimbo74's Avatar
a hi flow one... cats are pretty much universal, they are either stock flow or hi flow.... all they do is reduce harmful gas output.....
Old Jul 3, 2004 | 07:42 PM
4RUNR's Avatar
Guest
All the engine management relies on the 1st O2 sensor, the 2nd after the cat converter doesn't really do anything.
Old Jul 3, 2004 | 07:45 PM
jimbo74's Avatar
if the one after doesnt do anything? then why is it there? it uses if for something otherwise car amnufacturers wouldnt put one on there...
Old Jul 3, 2004 | 07:49 PM
88yotaboy's Avatar
Thanks for the info guys, any type of cat youd reccomend?
Old Jul 3, 2004 | 07:55 PM
jimbo74's Avatar
i have a catco, and they are hiflow
it depends.. there isnt really a difference between brand x and brand y... they all pretty much do the same thing........ except some are stock flow and some are hi flow
Old Jul 3, 2004 | 08:12 PM
4RUNR's Avatar
Guest
It works as an on/off switch to tell the computer if something went horribly wrong with the cat. It does not function in any way similar to the 1st O2 which actually detects temperature variations.
Old Jul 3, 2004 | 08:15 PM
carose725's Avatar
i got a dynomax high flow cat from summit racing. i think it was around $40
Old Jul 4, 2004 | 07:22 AM
88yotaboy's Avatar
$40 sounds good. I think im gonna order one up.
tj884Rdlx
Aug 28, 2015 12:04 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
