carb. help '85 22R
Old Nov 30, 2002 | 08:04 PM
growinseed's Avatar
Question carb. help '85 22R
'85 22r since major engine work I have trouble getting the high (warm-up)
idle to work. After engine reaches op. temp. runs smooth at 800rpm. I've
checked for vacuum leaks and tried adjustments of the three screws on the
carb. (two on linkage and one on carb. body, cleaned dirt/varnish from
linkage and 'butterfly' plates to no avail. My normal start sequence is
pedal to floor once then turn key. Before engine work it would hold high
idle (approx 1100rpm) until op. temp. then smooth out just fine. I don't
understand how having the intake manifold off could mess up the carb.
Any help would be greatly appreciated
Thanks
Nathan
Old Dec 1, 2002 | 07:00 AM
AZTOY's Avatar
Look and see if the choke is working.The choke helps the moter to start in cold weather and also make it idle higher when the moter is cold.
Old Dec 1, 2002 | 07:41 AM
growinseed's Avatar
Any ideas on what I might find. I'm hoping it is some linkage not operating because I can't pull the carb right now the truck is in need. Well its off to figure this one out. post later with a soultion
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
