car wont start - stuck at work :(
Old Jul 17, 2003 | 02:57 PM
joshik's Avatar
well i replaced the battery. it seems ok... for now! it fired right up
thanks again for all ur help!
Old Jul 17, 2003 | 04:25 PM
Gadget's Avatar
It sounds like you have two separate problems at once.
When you turn the key to start and hear a single distinct "CLICK" and the starter does not run, then that most likely is worn starter contacts in the soleniod. You can remove the starter and replace the contacts are just install a whole new starter. Getting it out is the hard part.
That rapid CLICK CLICK CLICK is caused by insufficent current to keep the solenoid engaged. It can be a weak battery or high resistance in the starter cable or ground cable.
The cure for a weak battery is to figure out why it is weak. It could be bad or the alternator is not recharging it properly, or again it could be high resistance in the cables.
The cure for weak cables is to identify which one(s) has high resistance by doing a voltage drop test and then replacing the bad ones.
Like I said, I think you have two different problems at once.
Good luck!
Gadget
www.GadgetOnline.com
Old Jul 20, 2003 | 05:51 PM
keisur's Avatar
Originally posted by NOTRUB
I could be wrong but I think you are talking about the starter relay! I have had to replace mine.
Nope. it is a 30A fuse.
Old Jul 20, 2003 | 08:41 PM
Adam F's Avatar
Your problem sounds EXACTLY the same as the problem I had. Click click click. I eventually burned out my cheap Wal Mart battery. Replaced it, worked fine for a month or 2. Then click click buzzzzzzz clikc click DEAD. Replaced the starter contacts and VIOLA! Works fine every time now. Here's a writeup I did on my V6
http://www.4x4wire.com/toyota/maintenance/starter/
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
gog1968
Jun 22, 2015 05:55 AM
