Camper Shell info..
Old Oct 31, 2002 | 08:31 PM
obxfishn's Avatar
Camper Shell info..
I am looking at buying a fiberglass campershell for my 02 Tacoma x-cab 4x4. The shell is coming off a 96 Toyota 4x4. Is there a change in the standard short bed from 1996 to 2002? Can anyone even say if this shell will fit? Any input would be beneficial. Thank you in advance!!!!!
Old Nov 1, 2002 | 07:55 PM
I am not sure. I would call around to canopy places and ask. I know my 93extra cab shell will not fit a 93 reg cab.
Old Nov 1, 2002 | 11:53 PM
bubbamango's Avatar
Shell
Dlouble check the seals and make sure they're not cracked or dried out, especially around the rear sliding window at the cab. That's where they are the most prone to leaking.
Stay away from the j-hooks, use the bolt attatchment instead. The j-hooks move and wind up bending the lip under the railing.
Old Nov 2, 2002 | 06:57 AM
Shane's Avatar
Re: Shell
My Snugtop shell uses J hooks, never had a problem with them. It stays tight no matter what, I've never had to retighten them, ever. So the bottom edge of the lip gets turned under a bit, so what. You can't even see that part unless you're lying on your back in the bed and looking for it. It's a hell of a lot better than having to drill holes in the bed rails for bolts or use those stupid c-clamps that always work loose.
Old Nov 2, 2002 | 10:40 AM
bubbamango's Avatar
I agree the c clamps are terrible. Hey, if the j-hooks work for you, great. But nothing holds the shell firmer in place than good 'ole bolts.
Old Nov 3, 2002 | 06:51 AM
Hermes's Avatar
As already suggested, call a local truck shop to make sure no problems. I didn't stay up on Taco's but as long as the cab lines are the same and the bed is same length you should be fine. The reason I mention the cab lines is you don't want 'dog ears'; this is where the shell sticks out further than the cab.
I used C clamps on my truck and never had a problem with them loosening up or moving. I also had an over-the-rail bed liner with cutouts for the clamps.
Brand names haven't really been mentioned, but I really liked my A.R.E. shell
urabus
Nov 10, 2015 07:38 PM
charlie_fong
Sep 27, 2015 10:06 PM
irv
Sep 23, 2015 08:30 AM
ToyotaMD
Sep 22, 2015 04:49 AM
83
18
Sep 21, 2015 06:15 PM
