Bled my Brakes, where is the LSPV?
I put in new brake fluid and bled my brakes today, but had no idea of where on the vehicle to look for the LSPV. Can somebody help me out with some fairly specific directions on where to look?
I assume that it will not be a problem to go back and bleed the LSPV next weekend or something since this is last valve in the order anyway?
1998 4Runner SR5 4x4 Desert Dune, rear diff breather mod
Re: Bled my Brakes, where is the LSPV?
Thank you MTL. I was a little worried about not finishing the job.
AgRunner, if you are referring to this thread:
https://www.yotatech.com/forums/show...highlight=LSPV
it doesn't really give a definitive answer.
If your truck has ABS it will not have a LSPV. If you do not have ABS you will find it on the frame above the driver's side rear axle.
Gadget
www.GadgetOnline.com
Gadget
Re: Re: Bled my Brakes, where is the LSPV?
Originally posted by MTL_4runner
A 4Runner does not have one....they are only on Tacomas
Re: Re: Re: Bled my Brakes, where is the LSPV?
Originally posted by kaiberg
my runner has one..i remember screwing with it when i did by shocks and coils...maybe only the 2nd gens ???
