Best ext. Themometer Sensor Placement
Old Aug 22, 2004 | 03:12 PM
flyAddict's Avatar
Question Best ext. Themometer Sensor Placement
Where is the best place to mount an external temp. sensor on a 4Runner?
I've tried the front right bumper corner. worked ok, temp climbed when standing still from engine heat but not as bad as the following. Today I ran it back along the frame to about 1.5 feet in from of the pass. side rear tire. This doesn't work so well either (yes, it dawned on me now the heat bleeding off the muffler is speading accross the bottom of the body and giving far too inaccurate temp info. So now I'm thinking I need to run it back up to the front bumper. Help. Thanks
Old Aug 22, 2004 | 03:41 PM
Cebby's Avatar
My one for my Gentex mirror is right under the left headlight. I also have the temp climbing issue. The recommended location for mine is in the middle, in front of the radiator, behind the bumper. I doubt that would not get engine heat either though.
Old Aug 22, 2004 | 06:18 PM
Jesters_taco's Avatar
What kind are you guys running? I have wanted one that tells temp and direction with time where the clock is
Old Aug 22, 2004 | 06:36 PM
flyAddict's Avatar
I think mine came from Target. It's mounted behind the gear shift, below the stereo. It measures internal, external temp and battery voltage. The voltage meter is very handy when I'm places where a battery too low to start the car would be a very bad thing. (I do have a portable jump pack to mitigate that danger though.)
jb451
7
Oct 7, 2022 06:58 AM
sanctfy
Sep 13, 2015 06:33 PM
Kreedy1
Sep 8, 2015 06:33 PM
LJR
Sep 5, 2015 06:02 AM
moparbay
Sep 3, 2015 12:48 PM
