Besides Supercharger how to increase power
Old May 23, 2003 | 11:39 AM
ChitRod's Avatar
is there an inexpensive way to increase power even slightly?
Old May 23, 2003 | 11:42 AM
Greedy's Avatar
Do a search on the forum for the "Deckplate Mod" and "Intake silencer Removal". These are cheap and effective ways to help the engine breath better..
Old May 23, 2003 | 11:44 AM
Mad Chemist's Avatar
Lose weight...
Old May 23, 2003 | 12:11 PM
ChitRod's Avatar
Originally posted by Mad Chemist
Lose weight...
I'm not that fat.
Old May 23, 2003 | 12:15 PM
No offense intended- its friday and I've had a loooong weak, so I'm a bit loopy at the moment.
Old May 23, 2003 | 12:32 PM
ChitRod's Avatar
none taken at all I know it's a joke when i see one. Hell if I removed the rear seats, took out the carpet, that would probably make a hell of a difference in speed.
Old May 23, 2003 | 12:34 PM
Seriously though, the deckplate mod, ISR mod, and a less restrictive air filter will make your engine quite a bit peppier for cheap.
Old May 23, 2003 | 12:47 PM
Corey's Avatar
Co-Founder/Administrator
Look in the Tech section here.
We have a few Deck Plate write-ups just waiting for you to read.
Old May 23, 2003 | 12:54 PM
AgRunner06's Avatar
Post
Lose weight...
Really he could, like this guy. This came up a while back in the off-topic section, but it's still pretty funny.
here
Just scroll down.
You could upgrade your exhaust system. Corey has some sound clips on his website of different mufflers.
You could put on a K&N. Lots of people have done this. I didn't because I have heard of people having trouble with their MAF sensor or AFM.
Then there is also the Deckplate and ISR mod.
Hopefully that was some help.
Old May 23, 2003 | 12:56 PM
ChitRod's Avatar
my only concern is that with the deckplate mod i'll screw something up.
Old May 23, 2003 | 01:13 PM
oly884's Avatar
Guest
Well, what type of toyota do you have and what engine do you have in it? That'll help get you started. With my 3.0L V-6 I just did intake. nothing special for my engine, get a free flow muffler and cat, intake, ignition, etc.
Old May 23, 2003 | 01:32 PM
ChitRod's Avatar
1996 4runner 3.4L
Old May 23, 2003 | 01:55 PM
oly884's Avatar
Guest
In that case I would go with the deckplate mod, the isr removal mod, and get either an exhaust system or a free flow cat and muffler. you'll definetly see some improvement from what I've heard.
Old May 23, 2003 | 04:07 PM
Zubaltec's Avatar
If you haven't done so already change your plugs and fuel filter.
Old May 24, 2003 | 09:51 PM
ChitRod's Avatar
I think I found the easiest way to gain some power. I'll put on one of these babies, I mean why not it works for all the civics doesn't it....ha ha.
Old May 24, 2003 | 10:25 PM
midiwall's Avatar
Originally posted by ChitRod
1996 4runner 3.4L
This is an easy engine to do the ISR mod on, it's very cheap (about $4) and easily reversible. The write-up is here:
https://www.yotatech.com/~corey/tech...ntake/dr_z.htm
[**edit**] I had originally posted the wrong link above, which is where the comments in later messages came from. "oops"
I did it (I have the same engine/year) using plumbing end-caps and it works great. I'm looking at doing it "cleaner" by re-piping from the MAF to the manifold, but that's mostly just for looks.
Like other folks have said, if you did the Deckplate, Freeflow air filter (Amsoil or K&N) and ISR, you'll DEFINITELY feel it. None of it is hard to do, the only potential worry point is cutting the hole for the deckplate, but if you take your time, you'll be fine.
Have fun!
Mark
Old May 24, 2003 | 10:26 PM
theronin's Avatar
There is only one tried and true way to get hp.... NAWWWWWZZZZZZZZZZZZZ!:pat:
Old May 24, 2003 | 11:44 PM
ChitRod's Avatar
http://us.imdb.com/CommentsShow?0322802
Have fun!
Mark
Yeah thanks Jackass if you don't want to help don't respond. But don't send me to a link claiming it's what I need ant it send me to a review on Jackass the movie.
Old May 25, 2003 | 05:10 AM
L33T35T 4Runner's Avatar
he probably accadentally posted the wrong link
Old May 25, 2003 | 08:50 AM
Dr. Zhivago's Avatar
Away
I'm sure Mark posted the wrong link accidentally. He does that occasionally.
You can find the links to the ISR mod article and the ORIGINAL write up for the DeckPlate mod by the person who pioneered it in my sig down below.
Hope this helps.
Dr. Z
