Besides Supercharger how to increase power
is there an inexpensive way to increase power even slightly?
Do a search on the forum for the "Deckplate Mod" and "Intake silencer Removal". These are cheap and effective ways to help the engine breath better..
Lose weight...:laugh:
Originally posted by Mad Chemist Lose weight...:laugh: |
No offense intended- its friday and I've had a loooong weak, so I'm a bit loopy at the moment.
none taken at all I know it's a joke when i see one. Hell if I removed the rear seats, took out the carpet, that would probably make a hell of a difference in speed.
Seriously though, the deckplate mod, ISR mod, and a less restrictive air filter will make your engine quite a bit peppier for cheap.
Look in the Tech section here.
We have a few Deck Plate write-ups just waiting for you to read. |
Originally posted by Mad Chemist Lose weight...:laugh: here Just scroll down. You could upgrade your exhaust system. Corey has some sound clips on his website of different mufflers. You could put on a K&N. Lots of people have done this. I didn't because I have heard of people having trouble with their MAF sensor or AFM. Then there is also the Deckplate and ISR mod. Hopefully that was some help. |
my only concern is that with the deckplate mod i'll screw something up.
Well, what type of toyota do you have and what engine do you have in it? That'll help get you started. With my 3.0L V-6 I just did intake. nothing special for my engine, get a free flow muffler and cat, intake, ignition, etc.
1996 4runner 3.4L
In that case I would go with the deckplate mod, the isr removal mod, and get either an exhaust system or a free flow cat and muffler. you'll definetly see some improvement from what I've heard.
If you haven't done so already change your plugs and fuel filter.
1 Attachment(s)
I think I found the easiest way to gain some power. I'll put on one of these babies, I mean why not it works for all the civics doesn't it....ha ha.
Originally posted by ChitRod 1996 4runner 3.4L https://www.yotatech.com/~corey/tech...ntake/dr_z.htm [**edit**] I had originally posted the wrong link above, which is where the comments in later messages came from. "oops" I did it (I have the same engine/year) using plumbing end-caps and it works great. I'm looking at doing it "cleaner" by re-piping from the MAF to the manifold, but that's mostly just for looks. Like other folks have said, if you did the Deckplate, Freeflow air filter (Amsoil or K&N) and ISR, you'll DEFINITELY feel it. None of it is hard to do, the only potential worry point is cutting the hole for the deckplate, but if you take your time, you'll be fine. Have fun! Mark |
There is only one tried and true way to get hp.... NAWWWWWZZZZZZZZZZZZZ!:pat:
Originally posted by mpulver This is an easy engine to do the ISR mod on, it's very cheap (about $4) and easily reversible. The write-up is here: http://us.imdb.com/CommentsShow?0322802 I did it (I have the same engine/year) using plumbing end-caps and it works great. I'm looking at doing it "cleaner" by re-piping from the MAF to the manifold, but that's mostly just for looks. Like other folks have said, if you did the Deckplate, Freeflow air filter (Amsoil or K&N) and ISR, you'll DEFINITELY feel it. None of it is hard to do, the only potential worry point is cutting the hole for the deckplate, but if you take your time, you'll be fine. Have fun! Mark Yeah thanks Jackass if you don't want to help don't respond. But don't send me to a link claiming it's what I need ant it send me to a review on Jackass the movie. |
Originally posted by ChitRod Yeah thanks Jackass if you don't want to help don't respond. But don't send me to a link claiming it's what I need ant it send me to a review on Jackass the movie. |
I'm sure Mark posted the wrong link accidentally. He does that occasionally. :laugh:
You can find the links to the ISR mod article and the ORIGINAL write up for the DeckPlate mod by the person who pioneered it in my sig down below. Hope this helps. Dr. Z |
