Ball joint spacers -- any issues?
Old Jul 19, 2004 | 02:29 PM
bain's Avatar
how much are these spacers and where could i get a set at for my 86?
Old Jul 19, 2004 | 02:52 PM
shiftless89's Avatar
Frank,
what happens when you use your spacers and add beafier torsion bars?? (ie sway away/downy) and are they needed with larger tires?
thanks
Mike
mvankeuren"at"vtaig.com
Old Jul 19, 2004 | 05:04 PM
mt_goat's Avatar
Originally Posted by shiftless89
Frank,
thanks
Mike
I have the spacers with 26mm Downey bars and I have them adjusted to the max softness. But I have Superlift upper control arms which changes everything.
Old Jul 21, 2004 | 08:47 AM
elripster's Avatar
Frank,
thanks
Mike
The only effect higher springs have is an increased spring rate. This is often not desirable since it decreases flex, however, there are exceptions. Examples are if you run a heavy bumper/winch combo, or like to jump a lot. Otherwise, the spacers typically soften the ride, the thicker bars will stiffen it back up to probably more than stock but not as much as without the spacers.
You can think of the spacers as things that give lift and more travel and the bars as only effecting how hard it is to compress the suspension since they don't in themselves provide any lift.
Frank
Old Jul 21, 2004 | 11:47 AM
  #25
elripster's Avatar
www.sdori.com
Frank
Old Jul 21, 2004 | 11:48 AM
  #26
elripster's Avatar
I'm wondering if I can get a head count as to who wants 1" spacers. I can mill them down this weekend and get shorter cap screws as well.
Frank
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
gillesdetrail
Aug 3, 2015 04:43 PM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
