Bad rear end cluck
Bad rear end cluck
well i just picked up a 2000 4runner. after about 200 miles of owning it i am getting a horrible clunk coming from the rear end. only sometimes when i'm driving like clunk clunk clunk... it doesn't go away when i put it in nuetral or in 4wd. when its making the noise and i hit the brake pedal i can feel it in the pedal like an up and down as i'm braking. i'm thinking maybe a bad u-joint in the drive shaft? i crawled under it and a quick visual showed the obvious to be ok.
any help would be great.
Merry Christmas
Merry Christmas
i just greased the hell out of the u-joints and both drive shafts. the noise seems to be quieter so atleast i know thats the problem, i am just gonna replace all 3 tomorrow when the parts stores open.
so i just got finished up with the fix. somebody installed the rear brake shoes wrong and the ebrake assembly came apart causing the noise from parts moving around in there.
now for the bad part i figured i'd replace the front rotors too and get rid of the pulsating. after adjusting the rear brake shoes to just have drag to stop the wheel after one turn, i bled all 4 brakes, got all the air out and still have the brake pedal go to the floor like it did before i did all the work. i did a bunch of reverse stops but it didn't help and the brake light is on now which it never was before. i am gonna start searching now but any help would be great. the only thing i saw in haynes was that there might be air in the abs control unit but it doesn't tell you how to blead that. thanks
icentropy
Jul 9, 2015 02:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
