axles wont come out
Old Nov 6, 2009 | 08:00 AM
stormtuner's Avatar
Exclamation axles wont come out
can someone please tell me why or how to remove the cv axles from my 96 taco? trying to replace center diff
Old Nov 6, 2009 | 08:10 AM
peapicker's Avatar
IF im not mistaken they are held in by a snapring, you have to be rough with em. pry bar between the housing and shaft maybe......
Old Nov 6, 2009 | 08:14 AM
stormtuner's Avatar
thanks,confirms what i thought just needed someone else to say so too...many thanks!!
Old Nov 6, 2009 | 08:17 AM
LanceN's Avatar
Just popped both of mine out last night.....Peapicker is correct.
Old Nov 6, 2009 | 08:41 AM
Ironmike4x4's Avatar
At work I always use a pry bar as pea said. If that doesn't work then a BFH and a long steel driver helps to persuade them out. Only problem with the last method is you need to use shop lift to get the full swing of the hammer.
Old Nov 6, 2009 | 04:30 PM
LarsDennert's Avatar
You may need to have a couple of clips handy for reinstall. Sometimes they break.
Old Nov 8, 2009 | 09:11 AM
CYi5's Avatar
Yep prybar. The most frustrating part of the whole job imo.
Old Nov 8, 2009 | 12:28 PM
Kerby J's Avatar
yea prybar is the way to go but i did happen to bend a 36" prybar so go figure
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
