awful vibrations
Old Aug 21, 2006 | 12:07 PM
dfoxengr's Avatar
awful vibrations
im getting a ton of vibrations when i let off the throttle, and sometimes when accelerating some.
i just installed my rb 2" bl, with new poly bushings, and new front rotors and pads.
the vibes were present before these two things but not as bad.
they started after my suspension lift, OME and tundra up front, alcan pack and bilsteins in the rear.
it is really violent sometimes, and i also hear a slow rotating thudding sound when im slowing down, which i believe to be my CV's. i did do a 1" diff drop with the susp lift though.
anyone have any ideas and or suggestions on what to check
thanks.
Old Aug 21, 2006 | 12:50 PM
kwikrnu's Avatar
You can remove front drive line from the transfer case to the front axle and if it still vibrates it may be the rear drive line or differential or axles.
Old Aug 21, 2006 | 03:08 PM
dfoxengr's Avatar
like take the front driveshaft out?
Old Aug 21, 2006 | 03:10 PM
garrett1478's Avatar
dunno the source of the vibrations, but the poly bushings are probably what amplified them.
Old Aug 22, 2006 | 01:03 PM
dfoxengr's Avatar
possibly the u joints? from the changed angfle of both front and rear?
they would be semi-binding twice per revolution and it would cause it to jerk...
Old Sep 6, 2006 | 09:44 AM
dfoxengr's Avatar
https://www.yotatech.com/forums/f2/found-source-vibration-driveshaft-whoa-94000/
check there for solution and answers...
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
Toys4parts
Sep 26, 2015 01:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
