Automatic Shifter Replacement??
Old Mar 14, 2005 | 04:48 PM
SD70MAC's Avatar
Is there any sort of shifter handle that I can replace the stock one with? I'm kind of tired of the stock computer joystick-looking shifter. I'd love to have something like a Hurst T-handle on there.
Old Dec 28, 2006 | 12:04 PM
jonykarate's Avatar
Sorry for bringing up such an old post, but I am also in the market for a replacement shifter for the auto tranny. Preferably one that is not so tall..
Old Dec 28, 2006 | 12:26 PM
mt_goat's Avatar
Good luck with that, the wiring for the OD switch is one tough problem and the shift lock stuff is another.
Old Dec 28, 2006 | 03:40 PM
Dublin's Avatar
You could put the shorter fatter shift nob from the 2WD automatic 4runner on in its place. Here's mine.
<a href="http://tinypic.com" target="_blank"><img src="http://i18.tinypic.com/2hwd6ch.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Dec 28, 2006 | 09:12 PM
reggie 00's Avatar
how did you do it?
Just the knob or the whole shaft as it attaches to the tranny?
Old Dec 29, 2006 | 04:19 AM
Dublin's Avatar
Just the knob, it's pretty tricky to reconnect the wires for the OD (their soldered to the switch) and the screw hole attaching the knob is in a different spot so you need to drill and tap a new one (or a tek srcrew could work). I like the slightly lower height and feel. Be sure you have time and patience to do this(not a quick and easy mod) once you start there is no turning back.
Old Dec 29, 2006 | 04:38 AM
mt_goat's Avatar
Is the shift lock button stuff the same for both?
Old Dec 29, 2006 | 06:07 AM
Dublin's Avatar
Yes they look different but only because of the knob design. It's just a swap of one complete knob assembly for the other.
Old Dec 29, 2006 | 04:16 PM
jonykarate's Avatar
thank you very much for the replies. Hopefully I can find one at a junkyard.
Old Mar 20, 2022 | 07:56 AM
97Gumbi's Avatar
With enough Dremel work and a dream.... Anything is possible. 😉🤣
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
crashburnoveride
Jul 10, 2015 06:39 AM
shar
Jul 9, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
