Auto to manual conversion help
I’m doing a manual swap on my 1999 Tacoma. Have have installed a 1998 Tacoma engine/ transmission harness and ecu. I know I’m going to have to ground a wire that would go the the clutch switch. Just wondering if anyone knows where I can find that wire or if some have a wiring diagram I could use. Also if there is any other wiring I’m going to need to do I’m not thinking of that would be a lot of help. Thanks
The clutch safety switch should use the same wire as the park/neutral safety switch.
do you have the pedal assembly? Master/slave cylinders? Are you going to bend hardline for hydraulics or use flexible braided? You dash
cluster is still going to have the PRNDL and may end up leaving one digit illuminated al the time.
Yes everything is installed pedal assembly, master/slave cylinder, factory hard/flexible line and it’s had a manual cluster in it for several years now. it just won’t start and that what I need help with
4runnerlover95
May 29, 2012 10:11 PM
AMSeiple
13
Feb 8, 2005 05:42 AM
