attempting tjm15 install... pics inside
Old Aug 8, 2006 | 08:30 AM
neliconcept's Avatar
Well Got my tjm15.. been looking at bobs writeup and still confused but not as much. so hopefully Im just gonna go whack at some #### for a bit to see what happens. Small questions. do I need to disconnect battery when I clip the fog light and turn signal wires?
i got the bumper from Jason B at burtmanindustiries.com
anyways I'll figure it out since Im smart enough to work a problem out I think lol
If i dont write back today.. I dropped the bumper on my head and im either in the hospital or im dead. anyways lol. haha but hopefully Ill get it all workin smoothly.
y'all think I can attempt all of this in 6 hours? I have to goto work at 6pm.
anyways pics here
old brushguard,, a guy at work I work with has a stock 02 so im gonna let h im have it... this brushguard was sold to me by jev2022 and he was awesome with everything, has been good to me just need something beefier
Old Aug 8, 2006 | 08:50 AM
northfacer581's Avatar
you gota take off that bumper first, which is pretty easy; then take off the tow hook and tow loop thing or shackle hangers, whatever you have down there
then put the brackets on, and then the bumper on; unless something like stripped bolts (like i had) pop up, you should be done pretty quick
and as far as the turn signals, just splice the wires; i dont think you have to disconnect the battery, i didnt; but i guess you could just to be on the safe side
Old Aug 8, 2006 | 08:57 AM
so I dont have to take the tow hooks off to get the bumper off? I know i'll have to take them off to put the tjm on but was just wondering. and in the picture which side is right and left of the brackets lol sry for stupid question.
bout to print up bobs writeup so I can see what im doing
Old Aug 8, 2006 | 09:13 AM
Intrepid's Avatar
Just get under there and start removing stuff, haha. Pull off the old bumper, the tow hook, and all the old bolts (save the bolts). Bolt the side wings onto the TJM, loosely bolt up the brackets to the truck, lower the bumper onto the brackets, put in bolts and nuts loosely. Now you can align the whole thing where you want it, then get underneath and tighten everything down. We used two hi-lifts to get it nice and level when we did it. It works great.
Old bumper off:
New mounts bolted up:
Lining up the new bumper using the patented dual-hi-lift method:
The finished product:
Only real problem is that we forgot to remove a stupid warning sticker about how the airbag won't work that is right on top...half under his grill once we tightened it down...
Old Aug 8, 2006 | 09:15 AM
OutdoorLiving's Avatar
Cherish the pics of your clean 4R.
It won't look like this after you take it wheelin' for the first time.
Old Aug 8, 2006 | 09:22 AM
oh yeah..
I have it loose as hell but I must be missin some bolts.. i feel like just kickin the damn bumper to the ground but that wont solve anything.
Im gonna eat then I'll take some pics of what I have so far. gonna look for any and all bolts to take off If I have too
Old Aug 8, 2006 | 09:26 AM
Intrepid's Avatar
That isn't mine, that is Pat161's. It isn't so clean anymore, he got broadsided in it, it is gone now. I have an '85 that I am accumulating large amounts of body damage on. Hahaha.
Old Aug 8, 2006 | 09:28 AM
Intrepid's Avatar
Originally Posted by neliconcept
oh yeah..
IIRC, there are 4 bolts underneath, holding the hooks on, then there are another 3 or 4 up inside the bumper on the front of each mounting plate, then there is one on each side wing holding it on. Just be careful, they are a PITA to get off if you strip them...ask Lee about when we did his, hahaha. I now own a full set of bolt-outs to alleviate this problem in the future.
Old Aug 8, 2006 | 09:39 AM
I got a stripper kit remover.. but I cant see for ÅÅÅÅ.. where are the wing holders at?
I do have the bracket bolts off on each side of the skid plate. and I havent taken tow hooks off but I didnt think I would have to just yet. well ill just take every damn bolt off I see under there.
Old Aug 8, 2006 | 09:43 AM
Localmotion's Avatar
hey..im in greenville right now. I dont think its too far from anderson. IF you want help let me know.
Old Aug 8, 2006 | 09:46 AM
PLEASE HELP ME OUT!!! lol
yeah man here is my number 864-226-9773
Old Aug 8, 2006 | 09:53 AM
Intrepid's Avatar
The side bolts are inside the wheelwell on the front of each side, if you get a flashlight and crawl underneath or pull off the plastic cladding from side the wheelwell, you may be able to see them,
If you look through the front of the bumper (the opening/grill part) you should be able to see the bolts on the front of the plate inside.
Old Aug 8, 2006 | 10:08 AM
ahhh those.. those bolts are not cooperating. I think i might have to use a drill.
Old Aug 8, 2006 | 10:13 AM
Intrepid's Avatar
Which ones are you talking about? The ones on the front of the plate or the ones on the sides of the bumper?
Make sure you are turning them the right way, also hit them with some deep creep or other penetrant. I think Lee stripped his because with the upside down, bolt facing forward thing, he got confused. His bumper was trashed anyway though, so we just cut a hole in the front of it after that, to give us straight access to the stripped bolt. The stud stands out from behind that plate because there are captured (welded on) nuts on there, so if necessary you may be able to take a pair of vice grips to the backside of the threads, but that will ruin them.
Old Aug 8, 2006 | 11:28 AM
i take it your talking about the ones that hook up the tow bolts?
BEFORE YOU DO ANYTHING......go to a muffler shop or something (tis what i did) and ask them for help....i went to meineke, they used a giant air powered socket drill, and the things came right off.
Old Aug 8, 2006 | 12:24 PM
Intrepid's Avatar
So what's the word? Did you get it done?
Old Aug 8, 2006 | 12:54 PM
04 Rocko Taco's Avatar
Updates? I wanna know how it went.
Old Aug 8, 2006 | 01:41 PM
thanks northfacer you saved me and matts lives.
I have the bumper on sorta.. its hangin on the brackets..
matt... i figured it out.. the bumper hangers go in between the frame hangers..
should have noticed that before
going to work now... might get it done tonight or tomorrow.. pics to come
Old Aug 8, 2006 | 02:07 PM
1985 4Runner's Avatar
Get that thing on there! Geez, you work slower than me!
You are going to be sooooo glad you put that on before Tellico.
If you haven't posted a new thread about your locker install, you might want to do it soon to have time to get some good install info.
Old Aug 8, 2006 | 02:16 PM
I think im gonna finish the bumper tonight.. wouldnt take me long to line up.. just need a spot light.
I didnt take pics of the plates but I think im going to pull bumper back off to do so for those who havent seen it yet.
OMG it lOOKS AWESOME lol
edit: and a big thanks to MATT! aka localmotion who came from greenville which is a hours drive to and from. and helped me out with getting the bumper intially off.
Thanks bro!!
