Ash tray mod :-)
Old Oct 21, 2002 | 03:12 PM
SLC Punk's Avatar
Originally posted by NDLunchbox
Don't forget to punch a little hole in the felt so your light will still shine through! Unless your light burned out like mind :-( I picked up a new bulb at my local Stealer today, the bastards charged me $2.50 for the smallest damn bulb I've ever seen in my life! I hate that dealership, can't wait to get back to my friends at Gates Toyota in Indiana!
Ps. Has anyone else's bulb burned out? I have a huntch that it was all the change ratteling around in there that shortened its life... the felt should help!
Damn that bulb cost $2.50!
My bulb is burned out, and I was planning on replacing it when I get the felt... But for $2.50..... Damn Stealers!!
Old Jan 10, 2003 | 06:39 AM
keisur's Avatar
haha
I did the same thing about two years ago but I was selfish and didn't post it. the change always seems to click against my wedding band since I take it off when I cruise the "B.L.V.D." in my PimpRunnuh.
Old Jan 10, 2003 | 06:41 AM
keisur's Avatar
hey you don't happen to have the part number for that light do you? could you email it to me? I want to order one when I order some other stuff from www.1sttoyotaparts.com.
thanks.
Old Jan 10, 2003 | 07:23 AM
SLC Punk's Avatar
thanks.
I actually took mine out and went to Autozone. I found one that was a tad wider, but still fit. THe cost was $1 for two bulbs and it works great!
Old Jan 13, 2003 | 12:41 PM
  #25
UKMyers's Avatar
Is anyone's felt lined ashtray light up blue like mine??
Old Jan 13, 2003 | 02:55 PM
  #26
sschaefer3's Avatar
Hey Bob-
"Future Mods on tap: PP 1" lift springs and BFG A/Ts"
You may want to re-think that. I thoroughly inspected AZ Rains and they have some definite issues.
They made the front springs the same rate to one side is higher than the other. They also seem to give a really good solid 2” of lift.
The Downey 20% over rear springs and a set of 1” front Cornbreds would be far superior to the quite obviously inferior PP springs.
Just telling ya what I saw.
Speaking of SAW's............................................. .......
Old Jan 13, 2003 | 03:05 PM
  #27
SLC Punk's Avatar
Steve, can you give me more info on the spring rate issue?
My front end (after the springs settled) was 1.5inches. So far they have been good springs.
Just curious, what would the following setup cost (an estimate)
Cornfed 2in spacers in front and Downey 20% over rear springs and a set of 1” front Cornbred?
Old Jan 14, 2003 | 04:45 AM
  #28
sschaefer3's Avatar
Measure very carefully and see if your drivers side is lower than your passenger side in the front.
AZ-Rain, Mike's is or was.
Old Jan 14, 2003 | 03:51 PM
  #29
sschaefer3's Avatar
Bump, any measurements?
Old Jan 15, 2003 | 06:11 AM
  #30
keisur's Avatar
I did the same. I got ansy and stopped by the local dealer to pick up an ash tray (coin tray in my runnuh) bulb, tail light bulb, and one for the glove box. man! they wanted between 5-8 bucks each! so I dropped my list in the trash and headed out to pep boys and, like SLC Punk said, $1 each! so I picked up two of each so I would have spares. it so happens that the same one that fits the coin tray fits the glove box and they come in packs of two (I think they are sylvania). make sure you grab the ones that say "for accessory lights" or something like that because I think they had some the same size but unless you looked closely they said "for center brake light" for something like that.
Old Jan 15, 2003 | 06:38 AM
  #31
JD's Avatar
JD
With some careful grinding I found a better use for my ash tray .
Ash Tray
Old Jan 15, 2003 | 06:41 AM
  #32
keisur's Avatar
haha
I thought I was having an acid flashback but then I looked and realized your from down under. I like the right side driving set up. nice mod.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
