ARB installed!
Old Jul 24, 2003 | 01:39 PM
Ducky's Avatar
Talking ARB installed!
Got my ARB and lights installed... Drove over to Jowie's so he could take pics...
Thanks Jowie...
Onward of the healing of the knuckles and to the next mod.
Old Jul 24, 2003 | 01:47 PM
Cebby's Avatar
Smokin'
Mad Chemist's Avatar
Sweet dude, going to Yotajam?
Old Jul 24, 2003 | 02:00 PM
Ducky's Avatar
As much as I want to, prolley not this year, I still have to re-adjust my SAWs and I just ordered Demello Sliders... and want those installed... not to mention the obligatory oil, tranny, dif fluid change, and since my airbox got destroyed in the accident redo my deckplate mod... and and and...
All small stuff I know...
Old Jul 24, 2003 | 02:03 PM
its2slo's Avatar
looks like they did a great job putting it back together.
Old Jul 24, 2003 | 02:48 PM
Sweet Bumper and Truck to go along with it
Old Jul 24, 2003 | 03:40 PM
smr4runner's Avatar
Oh my Ducky,
Does that look sweet.
I know your 4Runner is a few years newer than mine but did it install just like the Tacoma's.
There is a bolt that you are suppose to be able to bolt straight into the frame rail (where the end caps were removed. The holes on mine did not line up. How was yours set up?
Mike
Old Jul 24, 2003 | 04:01 PM
UNLIMITED96's Avatar
deja vu, looking good
i installed mine as well
i used air tools so it wasn't too bad
& i didn't split any skin
Old Jul 24, 2003 | 04:12 PM
Gene's Avatar
Re: ...
Not a single thing you mentioned should keep you from YotaJam! If you do not make it, I will have some choice words for you!
BTW: That rig is looking SWEET!
Ducky's Avatar
Post smr4runner
In the kit they come with the "blocks" you bolt onto the end of the frame rails, I didn't use them... (If thats what your talking about) I had a big plate welded at the end of each rail that had to be cut off... (I was amazed how small and thin the frames look) but obviouly held up well in my accident... then you all know the rest, drill a hole mount up the brackets... slide the bumper on.. Curse some.... ok.... alot... think that its not going to work.... and be amazed how it fits when you just shimmy it around.. the only difference from my friends tacoma install, was his gap between the fender and the top of the bumper seems closer, although I like my gap... because if it gets hit, it wont f-up my fender... I hope...
Anyone else who has Lightforce 170's I have a question.... My friends 170's didnt have anything on the back of his lights.. mine have a tube that they said I HAVE to install or it will void my warranty... I ran them into my engine compartment, and they have a filter on the end, no doubt a breather of some sort... my question is, is this a new thing or old?
Old Jul 24, 2003 | 05:04 PM
smr4runner's Avatar
Re: smr4runner
Yup. Mine came with all the 2000 + parts as well.
The only way I could see using the bolts was to weld a plate like you and Schaeffer did.
BTW UNLIMITED96. Since you have the 96, how did you bolt yours? Did you have to weld as well?
Thanks
Old Jul 24, 2003 | 05:10 PM
Ducky's Avatar
SMR
Wait.. Im not sure if I read that right... I didnt have to bolt that block on the end of the rails... I CUT the plate off.... I didnt weld it on...
Am I confusing or what?
Old Jul 24, 2003 | 05:16 PM
92 Toyota's Avatar
Picked my ARB up from Overnite Transport after work today.Holy s*** was it in a big box,barely fit in the back of my Tacoma.I can't wait till Saturday to install it.Yours looks great hope mine looks as good on my 03.
Old Jul 24, 2003 | 05:33 PM
EDGE's Avatar
Sweet, is their a difference between a TJM and an ARB or is it just 2 different companies making the same thing, different name of course
Old Jul 24, 2003 | 05:35 PM
NJ's Avatar
NJ
Looking sweet Ducky...
What rims are those, they remind me of the Land Rover Defender 110 Alloy rims that I wanted to put on my rig, but Land Rover are 5 hole, not 6...
Old Jul 24, 2003 | 05:54 PM
Ducky's Avatar
Stock toyota rims...
One of these days I might be tempted to get steel black rims... but I think these look nice..
Old Jul 24, 2003 | 05:58 PM
Ducky's Avatar
As far as difference, there are... You might want to search, theres several ppl banging their heads on whats better, ARB or TJM... the only thing I remember hearing is TJM might have better approach angle...
Old Jul 24, 2003 | 06:29 PM
NJ's Avatar
NJ
Re: ...
Was it an option.. if so what do they call them..
Thanx
Old Jul 24, 2003 | 06:58 PM
Ducky's Avatar
You know? Im not sure if they were an option, Mine is a sport, maybe it came as a sport package... Not sure though.. anyone know?
Old Jul 24, 2003 | 08:31 PM
NCSU-4runner's Avatar
i SO need to hit the lotto so i can afford all this stuff :pat:
