ARB Compressor wiring
Old May 9, 2004 | 07:56 AM
RTdawgs's Avatar
Two questions:
- for the Blu-Wht wire from switch #1, the diagram says "to dash illumination"...what is the purpose of this wire? the compressor is running without it.
- did you use loctite on the threads of the nipples when you installed them on the compressor per the ARB instructions?
Old May 9, 2004 | 08:06 AM
WATRD's Avatar
- So the switch lights up when you turn on the headlights, that way you can see it at night.
- No loctite, just teflon tape.
Old May 9, 2004 | 08:07 AM
Arnold's Avatar
I used Teflon tape as well.
GRNTACO's Avatar
Originally Posted by RTdawgs
Two questions:
The blu/wht for the illmination is for the swithces. When you turn your lights on they illuminate blue. I wired mine to..........can't remember but I can look if you want.
I used pipe dope and they leaked. Then I used teflon tape and no problems.
Old May 9, 2004 | 08:37 AM
RTdawgs's Avatar
where did you tap the Blu/Wht to?
Old May 9, 2004 | 08:42 AM
GRNTACO's Avatar
I will go look. I am almost sure I used on of the wires off the stereo........I am sure it was the factory wire used for the factory deck. I'll go look.
Old May 9, 2004 | 08:51 AM
GRNTACO's Avatar
I have it attached to the ''positive dimmer'' (org/wht wire) wire that is coming off the harness I bought to install my new stereo (didn't want to cut wires and void warranty). Since I don't have the factory deck anymore and my new deck doesn't use the dimmer wire I figured I would give it a try and it works.
Old May 9, 2004 | 09:45 AM
RTdawgs's Avatar
Thanks ben...ill go try later this afternoon.
Old May 9, 2004 | 10:23 AM
GRNTACO's Avatar
You're welcome. I also have a Factory Wiring Manual, for my Tacoma, but It may help locate a wire that will work.....
nick9455649
Sep 11, 2015 05:10 PM
stock87yota
Jul 31, 2015 10:08 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
