Anyone with a hood channel CB anatenna mount?
Old Jan 11, 2003 | 07:37 PM
TDiddy's Avatar
Anyone with a hood channel CB antenna mount?
I was looking over potential spots along the hood channel in preparation for installing my new CB and antenna mount tomorrow. I ordered a hood channel mount, similar to the one HBoss uses. Problem is, the hood seems to rub the bracket no matter where I test is out (on the drivers side at least).
Has anyone else had a similar problem? I'm going to try the mount on the passenger side tomorrow. But is SWR inherently better on the driver side or do you think it doesn't matter which side I use?
Tom
Old Jan 11, 2003 | 08:31 PM
BajaTaco's Avatar
I can relate
Yep - I have the hood mount too, and it rubs a little bit. I just plan to grind it down a little bit - no biggie. If your radio antenna is on the pass. side, then you would probably be better off mounting it on the driver's side.
Old Jan 11, 2003 | 09:04 PM
Corey's Avatar
Co-Founder/Administrator
I have pics of my old setup on my CB page listed on my homepage.
It did not rub, but it was a close fit.
Old Jan 11, 2003 | 09:20 PM
alanh's Avatar
You might check your hood to see if it is closer to the fender on the drivers side than the passenger side. When I was mounting my bracket (made to fit Toyotas), one of the CB place people said I might have to loosen the hood mounting bolts a bit and shift it a little toward the other side. I managed to fit mine without any hood moving (as Corey said, its close), so I haven't actually tried it. I think I'd be careful not to loosen things much though.
You do have to put the bracket so the offset (where the two bends are close together) lines up with the edge of the hood/corner of the fender. There isn't enough clearance to just have the bracket come straight up through the gap anywhere you choose. On mine, that limited me to one place, and I don't think the bracket would even work on the other side because of the angle of the bends.
I haven't noticed any obvious rubbing, but I wonder if there is enough hood/body movement to wear paint away over time.
Alan
HotNotch
Oct 8, 2015 06:51 AM
zombie_stomp
Aug 30, 2015 10:26 AM
msged2007
Aug 22, 2015 07:46 PM
Pedalpwr27
Aug 13, 2015 06:37 AM
Esibnitsud
Jul 30, 2015 08:19 PM
