Anyone ever use an Oil Extractor?
Old Oct 10, 2005 | 01:06 PM
Mason Dixon's Avatar
Has anyone used an oil extractor like the Pela 6000?
They are supposed to 'suck' the oil from your dipstick hole instead of draining it out from your drain plug. It seems like an easy to a home oil change without a lift, ramps, or jackstands (assuming that your oil filter is accessible from the top).
Do these things actually work well?
Old Oct 10, 2005 | 02:19 PM
steveh's Avatar
It would work except it would be a pita to make sure you get all the oil out, and it would be extremely slow because of the size of the dipstick tube. I've used a similar one, but much smaller, to extract oil samples for testing.
Old Oct 10, 2005 | 02:37 PM
bob200587's Avatar
Its the same as the pumps they use for closed system automatic transmissions. I know its alot more of a pain than jacking up one side and gettin on the creeper.
Old Oct 10, 2005 | 03:24 PM
AW1090's Avatar
how low is your 2000?......just slide underneath and pop the bolt out to drain it. Before I put any lift on mine it still seemed like I had more than enough room to work under there.
Old Oct 10, 2005 | 03:27 PM
TDiddy's Avatar
Very popular in the BMW world.
Old Oct 10, 2005 | 04:10 PM
marko3xl3's Avatar
Probably because they run body kits which leaves them with less than an inch of clearance
Old Oct 10, 2005 | 05:29 PM
TDiddy's Avatar
The oil filter housing is in the engine bay, right up on top at least on e46's, not sure about others. Anyway it makes the oil extractor very practical. I think some VWs have the same setup.
Old Oct 10, 2005 | 11:49 PM
bulldog-yota's Avatar
The new V6 4RUnner and Tacoma is a perfect candidate for this too. Now crawling required for an oil change.
Old Oct 11, 2005 | 06:49 AM
Bennito's Avatar
I haven't used one. BUT - I've watched the oil butler use one. Oil Butler is a company that does mobile oil changes. Using that thing eliminates the mess and need for jacks etc. Worked well for them. but i didn't watch them clean it up etc.
Old Oct 11, 2005 | 07:48 AM
MNBOY's Avatar
Extractors are used for almost all inboard marine engines because the drain plugs are inaccessible. They work OK but they do leave some oil behind. Depending on how picky you are it really isn't a problem, and they are so much cleaner than any other method. You do still have to get to the filter, which for marine engines usually dumps oil all over the place and negates the clean part of the job.
If you want to buy one look at the marine stores and they will have a bunch of options, I use a Tempo model that works very well.
Old Oct 11, 2005 | 10:08 AM
dallison's Avatar
the one i use
i have used it on my rl, the 4runner and accord with no problems, my acurazine thread
http://cl.acurazine.com/forums/showt...ight=extractor
Old Oct 11, 2005 | 02:25 PM
dgb9902's Avatar
works great
I have used them on my boat engine 4.3 chevy/merc and my sons honda.
Old Oct 11, 2005 | 05:47 PM
Marc P's Avatar
I ran a boat maintenance business for a while. We had fancy ones that could pull and hold up to 30 qts of oil with a single charge. I was looking for some pics, cant find them.
Old Oct 11, 2005 | 06:07 PM
FirstToy's Avatar
I use the one from Griots Garage, works great. Removes full published capacity (about 5L in my case). I've never removed the oil plug ever, it's the original since I bought mine new. Filter is next to the battery so oil changes are a snap.
Old Oct 11, 2005 | 06:11 PM
Rivalred's Avatar
I might invest in one of these and start doing my own oil changes again.
Old Oct 11, 2005 | 06:40 PM
dallison's Avatar
if you search around, you can prob get one for less than $60 shipped
Old Oct 11, 2005 | 06:55 PM
grimpy's Avatar
You might as well just use the drain plug... It's easy as heck... You should be able to fit under the Runner without lifting it or anything and you still need to get under the sucker to get the oil filter out.
Old Oct 11, 2005 | 06:58 PM
grimpy's Avatar
My prev BMW's were all pretty low to the ground... I still lifted the sucker up to change the oil... But for a BMW, it may be worthwhile since you have to remove the pos lower engine cover thing just to access the drain plug. Also BMW oil filters are on top right next to the engive cover...
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
