any one have a sticky gas gauge in a 3rd gen ?
Old 01-29-2005, 06:13 PM
Stegall984R's Avatar
Location: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
Ive noticed over the last few weeks my gas gauge has be sticking in low positions. It seems like very since it got cold it started this mess. Any one have a simialr problem ? Also, has any one done a sending unit swap? How big of a PITA is it ??
Old 01-29-2005, 07:25 PM
User 051420's Avatar
This is a known issue with 3rd gens. There are a few threads about it around somewhere.....I don't think there's a surefire fix.
Old 01-29-2005, 07:32 PM
Bob_98SR5's Avatar
98,
the gas gauge problem is only for 99s (all of them) and some 00s. TSB EL010.
sorry that doesnt answer your question but i didnt want you to go the tsb el010 route
bob
Old 01-29-2005, 07:33 PM
Thanks Bob! I stand corrected.
Old 01-30-2005, 06:25 AM
so the TSB dosnt effect me... any other ideas to fix the sorry thing ?
Old 01-30-2005, 10:13 AM
kevin444's Avatar
I suffer the el010 tsb. My local stealership wants $900 to correct it.
Old 01-30-2005, 10:17 AM
BruceTS's Avatar
Ironically, my 99" was on the list for the TSB, but I waited too long to go in to get it done. After I smashed in my tank to the point where I couldn't pick up all the fuel, it was time to fix it. So after running out most ofthe fuel, I dropped my tank, which was quite easy. then pulling the pump assembly out. At the same time I inspected the fuel sending unit, it has a wiper arn that contact a variable resistor, I put slight pressure on the arm and cycled the guage assembly to clean the contact surface. ever since I did this my sending unit has worked flawlessly.
Old 01-30-2005, 11:33 AM
Albuquerque Jim's Avatar
Mine has gotten wierd when wheelin' in high angle situations, but has always evened out.
Old 06-28-2016, 04:35 AM
Whetherman's Avatar
Sticky gas guage
I just bought a 02 Tundra SR5 regular cab. The fuel gauge sticks at full, and at a bit above a quarter full. In both cases when I rap on the gauge cover, it drops into it's correct position. I have yet to figure out the root of the problem, but any help would be appreciated.
Old 06-28-2016, 10:52 AM
ThorInc's Avatar
I would think this is likely a bad ground.
Old 06-28-2016, 11:49 AM
habanero's Avatar
Thor...you remember a thread about the circuit board in the cluster being an issue? May have been just the 99s though, I wasn't paying enough attention at the time. Looked, but couldn't find the thread.
Old 06-28-2016, 12:39 PM
ThorInc's Avatar
I just Google searched this and had a bunch of hits including two results from this site, here is the link to the search:
https://www.google.ca/search?q=3gen+...M6aMjwTKv67gBg
Old 06-28-2016, 01:22 PM
habanero's Avatar
I knew you'd be better at that than I was! Didn't see the thread in question, tried images too, I'm remembering the circuit board being messed up, burned or something, and it was either repaired or replaced. At least your search pulled up a lot of interesting reading to get started on.
Old 06-29-2016, 03:23 AM
Whetherman's Avatar
Thank you Thor
Old 06-29-2016, 02:12 PM
sharrack's Avatar
Mine goes haywire every now and again. Not worried unless it totally goes south.
smthwsn357
12-04-2023 02:08 AM
Jdgarrison
10-01-2015 05:22 PM
shisha1999
09-21-2015 08:22 PM
HollieJayyy
08-09-2015 07:59 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: any one have a sticky gas gauge in a 3rd gen ?
