any one have a sticky gas gauge in a 3rd gen ?
Old Jan 29, 2005 | 06:13 PM
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
Ive noticed over the last few weeks my gas gauge has be sticking in low positions. It seems like very since it got cold it started this mess. Any one have a simialr problem ? Also, has any one done a sending unit swap? How big of a PITA is it ??
Old Jan 29, 2005 | 07:25 PM
User 051420's Avatar
This is a known issue with 3rd gens. There are a few threads about it around somewhere.....I don't think there's a surefire fix.
Old Jan 29, 2005 | 07:32 PM
Bob_98SR5's Avatar
98,
the gas gauge problem is only for 99s (all of them) and some 00s. TSB EL010.
sorry that doesnt answer your question but i didnt want you to go the tsb el010 route
bob
Old Jan 29, 2005 | 07:33 PM
Thanks Bob! I stand corrected.
Old Jan 30, 2005 | 06:25 AM
so the TSB dosnt effect me... any other ideas to fix the sorry thing ?
Old Jan 30, 2005 | 10:13 AM
kevin444's Avatar
I suffer the el010 tsb. My local stealership wants $900 to correct it.
Old Jan 30, 2005 | 10:17 AM
BruceTS's Avatar
Ironically, my 99" was on the list for the TSB, but I waited too long to go in to get it done. After I smashed in my tank to the point where I couldn't pick up all the fuel, it was time to fix it. So after running out most ofthe fuel, I dropped my tank, which was quite easy. then pulling the pump assembly out. At the same time I inspected the fuel sending unit, it has a wiper arn that contact a variable resistor, I put slight pressure on the arm and cycled the guage assembly to clean the contact surface. ever since I did this my sending unit has worked flawlessly.
Old Jan 30, 2005 | 11:33 AM
Albuquerque Jim's Avatar
Mine has gotten wierd when wheelin' in high angle situations, but has always evened out.
Old Jun 28, 2016 | 04:35 AM
Whetherman's Avatar
Sticky gas guage
I just bought a 02 Tundra SR5 regular cab. The fuel gauge sticks at full, and at a bit above a quarter full. In both cases when I rap on the gauge cover, it drops into it's correct position. I have yet to figure out the root of the problem, but any help would be appreciated.
Old Jun 28, 2016 | 10:52 AM
ThorInc's Avatar
I would think this is likely a bad ground.
Old Jun 28, 2016 | 11:49 AM
habanero's Avatar
Thor...you remember a thread about the circuit board in the cluster being an issue? May have been just the 99s though, I wasn't paying enough attention at the time. Looked, but couldn't find the thread.
Old Jun 28, 2016 | 12:39 PM
ThorInc's Avatar
I just Google searched this and had a bunch of hits including two results from this site, here is the link to the search:
https://www.google.ca/search?q=3gen+...M6aMjwTKv67gBg
Old Jun 28, 2016 | 01:22 PM
habanero's Avatar
I knew you'd be better at that than I was! Didn't see the thread in question, tried images too, I'm remembering the circuit board being messed up, burned or something, and it was either repaired or replaced. At least your search pulled up a lot of interesting reading to get started on.
Old Jun 29, 2016 | 03:23 AM
Whetherman's Avatar
Thank you Thor
Old Jun 29, 2016 | 02:12 PM
sharrack's Avatar
Mine goes haywire every now and again. Not worried unless it totally goes south.
smthwsn357
May 1, 2024 07:28 AM
Jdgarrison
Oct 1, 2015 05:22 PM
shisha1999
Sep 21, 2015 08:22 PM
HollieJayyy
Aug 9, 2015 07:59 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
