Antenna Question
Old Jun 3, 2003 | 04:01 PM
Praufet's Avatar
Antenna Question
I have a motorized antenna on my 94 4runner and I want to switch over to a fixed powered antenna. My question, is the power for the stock antenna always hot or just powered when it is extending/retracting?
Old Jun 3, 2003 | 04:52 PM
4x4CPOSEADOG's Avatar
Praufet,
I have just replaced my power antenna with the fixed mast antenna. I never heard such a fixed powered antenna. The fixed mast antenna I installed this weekend has no power, it is basically a solid antenna bolted on the bracket where the power antenna was bolted on. Here is the part # 86300-39145 and cost me $21.50 at the dealer. This antenna is sweet and I don't hear no motor winding up or down. The power antenna has a connector inside the fenderwell, you have to disconnect that connector, loosen the chrome nut on top of the fender, once the nut is off, unbolt the motor and pull it out of the fender well. But before you do this, don't forget to disconnect the cable from the back of your radio. You are going to remove the glove box compartment, the dash that hold the ashtray, and the dash that hold the stereo. It is a piece of cake to switch from power to fixed mast antenna.
Noel
Old Jun 3, 2003 | 05:04 PM
Praufet's Avatar
I guess I really didn't describe my antenna right. I got it from autozone, it's an amplified antenna, hence the need for power, and was way under $20.
Old Jun 3, 2003 | 05:06 PM
4x4runner's Avatar
depending on the stereo, the power is usually hot when the tuner is on, and dead when the cd player is on or the unit is off.
Old Jun 3, 2003 | 05:08 PM
Praufet's Avatar
I have an aftermarket stereo, and the existing antenna stop extending/retracting after it was installed.
Old Jun 3, 2003 | 05:21 PM
Posted by Praufet
Mine did the same thing too, it won't extend or retract. But I still have the factory radio/cd on my rig. I came to find out the reason why it won't extend or retract is because the plastic track inside the motor housing is broken. So I ended replacing it with fixed antenna from the dealer.
BTW, you need to put your signature so we know what kind of rig you have. Put your vehicle year, model, tranny, and a little description.
Noel
Old Jun 3, 2003 | 07:48 PM
Praufet's Avatar
With mine I don't even hear the antenna motor try to move.
Old Jun 3, 2003 | 09:25 PM
nofilter's Avatar
praufet, when you put in the aftermarket stereo, did you connect the amp lead to the antenna power? i think this is what i did to make the power ant.work. basically, the power ant. needs the signal to activate the motor. when you turn off the stereo, the amp lead turns off, and then the antenna drops.
Old Jun 3, 2003 | 10:07 PM
Praufet's Avatar
I didn't install the stereo, installation was free with purchase.
Old Jun 4, 2003 | 07:26 AM
nofilter's Avatar
ok then, to answer your first question, i think there is contant power in the harness at the power antenna motor.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TDonkey
Jul 26, 2015 10:14 AM
