Antenna Help
Old Mar 16, 2010 | 09:49 PM
Chrispychilla's Avatar
Antenna Help
Does anyone know if I can find a replacement for my power antenna that ISN'T a power antenna. Like one that is flexable. My motor AND mast is broken, I am unemployed and can't afford to pay for the entire thing to be replaced. thanks. BTW I got a 2000 4Runner Ltd.
Thanks!
Old Mar 16, 2010 | 10:35 PM
stockwell45's Avatar
here ya go bud
http://www.4runners.org/writeups/whip/index.html
hope this helps
Old Mar 17, 2010 | 08:49 AM
AlexJet's Avatar
Non-motorized antenna 86300-35090 $40
Tacoma Wip 86309-AA040 $45
Old Mar 18, 2010 | 06:06 AM
Ritzy4Runner's Avatar
Have you tried any local wrecking yards? for the price of a new non-retracable, you could pick up a used one from another 4runner for less I'm sure. Also look for replacement antenna internal. They do make replacement internals as the nylon gear strips do break on occasion. they usually are not very expensive and its not that hard to replace. Just a thought. Good luck
Old Mar 18, 2010 | 07:38 AM
mattfarkas's Avatar
reccomendation
don't buy a cheap replacement and try to make it work. i just did that with a $13 autozone antenna. It went awful. i'll be going to the junkyard and getting one.
Old Mar 18, 2010 | 12:25 PM
Elton's Avatar
i went to the junk yard got a tacoma whip set up for like 10 bucks fit perfect
Old Mar 18, 2010 | 08:52 PM
pendrag's Avatar
Are you 100% sure the motor is dead, and that the antenna mast track isn't just stripped? The track looks like a plastic zip tie with deeper treads that goes inside the antenna mast. It can get stripped so that the motor can't run the mast up and down.
Old Mar 18, 2010 | 09:18 PM
Yea, I tried replacing the mast already. All the teeth in the motor drive are destroyed.
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
