Another Toyota Cheap Trick - Under $10.00 - Caution dialup, kinda big pics
Old Feb 20, 2005 | 11:38 AM
azrain's Avatar
For those of us who pull interior panels for access to areas underneath them, you may have experienced what I call the "one time assembly fastener" that Toyota uses on plastic interior panels. These are prone to breaking, stripping out from repeated installation, wear, etc. Here's a pic of an abused panel for a visual example:
As you can see, one of the two fasteners is broken and the other one is well on its way.
Well, I just got tired of panels squeaking and flopping around loose, so I went to ACE Hardware and picked up a handful of nylon panel nuts to give them a try. At a whopping $.26 each, what did I have to lose? As it turned out, these worked perfectly. Here are some pics of the panel nut:
These are meant for a #10 screw with a 3/8" X 3/8" opening. The openings (for the most part) in a 3rd Gen. 4Runner are at least .340 X .340 making these perfect for the application. I did have to drive the panel nuts into the perfectly square openings with a 1/2" ratchet extension and a deadblow, but they went right in. Pics of the installation:
Door sill application
Rear Hatch sill application
After cutting about a 3/8 of an inch off the bottom of the interior panel standoff / fasteners, the door sill went in perfect and are mounted extremely solid using the factory screws. Not bad for about $6.00 and an hour worth of work.
Mike
Old Feb 20, 2005 | 11:43 AM
waskillywabbit's Avatar
Awesome find...I'll have to look into that for my 85.
Cheap and effective is my kinda mod!
Old Feb 20, 2005 | 12:11 PM
ugadawg95's Avatar
Mike
Can you explain this further please? This is EXACTLY what I need to do to my drivers side door sill cover! Great thinking!
Old Feb 20, 2005 | 12:15 PM
Ironmike4x4's Avatar
Sweet! I've had to take mine apart several times for wiring CB's strobe lights, and etc. so that helps out alot. Good job.
Old Feb 20, 2005 | 12:18 PM
Buy the panel nuts. Smack them in w/ a 1/2" extension and a BFH and shave some off your trim piece on the backside so it'll sit flush. Screw it on. You Georgia bulldogs ain't too smart are ya?
Old Feb 20, 2005 | 12:27 PM
azrain's Avatar
That's about the long and short of it.
Mike
Old Feb 20, 2005 | 01:02 PM
Mike
Old Feb 20, 2005 | 01:12 PM
ugadawg95's Avatar
Mike
Thanks Mike. I looked at my local ace hardware with no luck. Was it in with the rest of the hardware in those little drawers? Or was it in another location?
Old Feb 20, 2005 | 01:13 PM
ugadawg95's Avatar
Somehow I knew I was going to get a smarta$$ comment from you.
Old Feb 20, 2005 | 01:22 PM
azrain's Avatar
Yeah, they are in the Hillman drawers (Hillman is a major retail fastener distributor.) They are also likely available at Lowes / Home worthless Depot, etc. I'll try to get the P/N next time I'm in there.
The point of the ratchet extension was to drive the panel nut home since I was too lazy to look for my drift punches and I couldn't get the head of the BFH in there to drive the nuts into the hole. Dang, all of that does NOT sound right, but that's the case...
Mike
Old Feb 20, 2005 | 01:26 PM
ugadawg95's Avatar
Mike
LOL!!!! Thanks Mike, that would be great if you could get the part number. These door sill covers have been driving me nuts!!!
Old Feb 20, 2005 | 01:30 PM
You dawgs are such easy targets!
Old Feb 20, 2005 | 06:34 PM
Jake94's Avatar
Napa part # 665-1002
$5 for a 20 count bag. Used 'em to fix the squeeks in my dash. Worked great.
Jake.
Old Feb 20, 2005 | 06:54 PM
azrain's Avatar
Knew I wasn't the first, thanks.
Mike
Old Feb 20, 2005 | 07:08 PM
Bob_98SR5's Avatar
hey mike,
i had to do exactly what you did when i tore out my entire interior for my sound deadening mod. those things are the best!
they also work in the holes for the fender flare bolts.
bob
Old Feb 21, 2005 | 05:46 AM
TRDDude's Avatar
Thanks for the tip!! I just broke those tabs this past weekend on my door sills.
Old Feb 26, 2005 | 04:53 PM
ugadawg95's Avatar
I picked up some panel nuts at Lowes, snapped them in and re-installed the door sill covers. Great idea!!!
Old Feb 26, 2005 | 06:24 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Awesome idea, something to pick up at Lowe's this week.
Old Feb 26, 2005 | 06:42 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Kudos, gents! A great solution for a common problem!
Spicer
Apr 7, 2026 07:17 PM
6th Gear
19
Dec 10, 2019 07:31 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
shadowbirdie
Jun 18, 2015 06:38 PM
