Another Question
Old Nov 5, 2003 | 09:07 AM
NVRSASTK's Avatar
Another Question
I have a 99 Limited 4 wheel drive. How do you know if it has a fatory locker in it or not?
Old Nov 5, 2003 | 09:08 AM
Jonathan's Avatar
There is a switch inside the truck that will say RR Diff Lock. It's located on the left -hand side of the dash.
SLC Punk's Avatar
There should be a button on the dash, just left of the steering wheel. By the dimmer.
It should say RR DIFF
Or look at your rear diff for the locker motor.
Old Nov 5, 2003 | 09:09 AM
SLC Punk's Avatar
Beat me to it!!
Old Nov 5, 2003 | 09:11 AM
NVRSASTK's Avatar
Thanks alot guys
Just curious which models normally have that? I thought being a Limited I woould have that stuff I guess not... That sucks
Old Nov 5, 2003 | 09:32 AM
Jonathan's Avatar
Check out Jalaber's site he has a bunch of info on the 4Runner on there and you cna probably find what your looking for a lot easier. But to answer your question, they made them from 99 on up to 2002, but I think you had to either order it that way or it was just luck of the draw. The e-locker only came on the 4x4 Runners and was not specific to either the SR5 or the limited, it just depends on how it came from the factory. I may be a little off on some of this but just check that site and it should help you out i believe.
Old Nov 5, 2003 | 09:52 AM
CTB's Avatar
CTB
Actually, I think they were only available from 1996-2000. After that came the multi-mode AWD/4WD system.
Just trying to keep you Carolina guys straight......
Old Nov 5, 2003 | 09:54 AM
Jonathan's Avatar
HAHAHa, yeah you're probably right Cody, haven't really looked too hard into it, all i know is that I want one
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
