Another Cargo Drawer Build...
Old May 19, 2009 | 07:36 PM
Mojo_Risin's Avatar
Working on completing my rear cargo drawers. About 75% done... Similar but a little different than some of the other builds in the past... I am building two - am planning on selling the other. Will update as I finish...
John
Old May 19, 2009 | 08:15 PM
RMA's Avatar
RMA
Looking Good John.
Old May 20, 2009 | 05:26 AM
SnowRunner98's Avatar
Awesome!
Old May 20, 2009 | 08:02 AM
andreas970's Avatar
That looks a lot like what I'm planning, except mine will have an extension for when the seats are folded down.
Do you have measurements?
Also, what kind of wood/slides did you use?
Thanks!
Old May 20, 2009 | 02:29 PM
Mojo_Risin's Avatar
Thanks!
no, exact written down measurements. but basic measurements...
main box to hold drawers was 38x38"
drawers were approx 16"x37"x8"
Top was approx 52"x41"
I used 28" 125# rated drawer slides.
Drawers and box made from 15/32" 4X8 ARAUCO PLYWOOD ACX
Top platform is 3/4" regular plywood.
The top is one solid piece - not mounted to the box - so we can get it in and out without a hinge. It has cleats on the bottom of the platform to keep it in place - and once i add the trap door rings - i will have 4 eyebolts on the bottom of the top platform that will hook to the turnbuckles and keep it all in place.
I still need to add the trap door ring tie downs, the turnbuckles, carpet, latches, etc....
John
Old May 20, 2009 | 03:21 PM
Corey's Avatar
Co-Founder/Administrator
Nice, Mojo workin' his mojo
Looking forward to the end result John.
Old May 20, 2009 | 07:06 PM
BajaRunner's Avatar
Thats the plywood I used. Expensive but nice
Old May 21, 2009 | 04:27 PM
rugerm44's Avatar
Dam nice.What do you figure it on the weight.I want to build one for carrying everything to the gun range.They are proud of those diamond plated tuffy drawer systems.1,500 is a little steep.
Old May 21, 2009 | 06:28 PM
Mojo_Risin's Avatar
I'd guess around 120lbs. I think if you design it right you could make it lighter. Plus you could just add some diamond plate to the drawer faces if you wanted.
John
Old May 25, 2009 | 05:01 PM
Mojo_Risin's Avatar
Update...
Pretty much done - just need to add nylon loops to drawer fronts for easier opening...
Old May 25, 2009 | 05:06 PM
toyospearo's Avatar
So sweet!!!
Great work!
Old May 25, 2009 | 05:47 PM
89silverpu's Avatar
Looks awesome!! If I had a 4runner I'd definitely make one of these! But I've got a whole bed to throw my crap in
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Obmi
Oct 4, 2015 11:30 AM
Badfish740
Sep 4, 2015 04:21 AM
terminator
Aug 31, 2015 11:32 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
