Another Cargo Drawer Build...
Working on completing my rear cargo drawers. About 75% done... Similar but a little different than some of the other builds in the past... I am building two - am planning on selling the other. Will update as I finish...
http://home.earthlink.net/~jmstavola/IMG_7579_1.JPG http://home.earthlink.net/~jmstavola/IMG_7592_1.JPG http://home.earthlink.net/~jmstavola/IMG_7593_1.JPG John |
Looking Good John.
Awesome!
That looks a lot like what I'm planning, except mine will have an extension for when the seats are folded down.
Do you have measurements? Also, what kind of wood/slides did you use? Thanks! |
Originally Posted by andreas970
(Post 51144255)
Do you have measurements? Also, what kind of wood/slides did you use? Thanks! main box to hold drawers was 38x38" drawers were approx 16"x37"x8" Top was approx 52"x41" I used 28" 125# rated drawer slides. Drawers and box made from 15/32" 4X8 ARAUCO PLYWOOD ACX Top platform is 3/4" regular plywood. The top is one solid piece - not mounted to the box - so we can get it in and out without a hinge. It has cleats on the bottom of the platform to keep it in place - and once i add the trap door rings - i will have 4 eyebolts on the bottom of the top platform that will hook to the turnbuckles and keep it all in place. I still need to add the trap door ring tie downs, the turnbuckles, carpet, latches, etc.... John |
Nice, Mojo workin' his mojo ;)
Looking forward to the end result John. |
Thats the plywood I used. Expensive but nice :)
Dam nice.What do you figure it on the weight.I want to build one for carrying everything to the gun range.They are proud of those diamond plated tuffy drawer systems.1,500 is a little steep.
Originally Posted by rugerm44
(Post 51145473)
John |
Update...
Pretty much done - just need to add nylon loops to drawer fronts for easier opening... http://home.earthlink.net/~jmstavola/IMG_7637_1.JPG http://home.earthlink.net/~jmstavola/IMG_7638_1.JPG http://home.earthlink.net/~jmstavola/IMG_7639_1.JPG |
So sweet!!!
Great work! :bowdown2: |
Looks awesome!! If I had a 4runner I'd definitely make one of these! But I've got a whole bed to throw my crap in :D
