Alignment
Old May 19, 2004 | 09:30 PM
cjrl's Avatar
Alignment
Hey guys. I have an '87 runner that I'm having some alignment problems with. It seems if I let go of the wheel I will drift slightly to the right. I just recently checked the air pressure in the tires and one was 40 while the other was 30. So I put them both at 35psi (recommended) and I'm still having some problems with the drift. I'm starting to get worried it's a little more than the tires and I am not excited about paying for some work done on it. Anyone experience this sort of problem, is there anything I can check before I would take it into the shop
Old May 19, 2004 | 09:37 PM
bike4miles's Avatar
As far as a check goes, it sounds like you already have that covered. You are going to cook your tires real fast if it is out of alignment. It is prbably a little squirly too. It's worth $40 to get it done. That's one of the first things I did when I got my 91 runner. Just make sure you see a specialist because I lot of the tire places don't have a clue when it comes to non stock tire sizes and they sometimes make it worse.
Old May 19, 2004 | 09:47 PM
cjrl's Avatar
Thanks for the info. Do you know any good chains you might recommend for tire alignments? I should probably just get this out of the way.
Old May 20, 2004 | 06:08 AM
foxtrapper's Avatar
Guest
You know that roads are crowned to shed rain, and as a result vehicles will normally drift to the right.
Old May 20, 2004 | 07:53 AM
eric-the-red's Avatar
And drifting to the right is a lot safer than drifting to the left
Old May 20, 2004 | 09:19 AM
Flamedx4's Avatar
Call your local 4 wheel drive shop and ask them who they recommend. The "chains' are rarely any good, they just go by the book. Find the guys who really understand the stuff.
Old May 20, 2004 | 09:27 AM
bike4miles's Avatar
I agree
Old May 20, 2004 | 02:27 PM
Horseshoeing's Avatar
Whta state and city do you live in? It you live in Ga I know someone.
Old May 20, 2004 | 07:50 PM
cjrl's Avatar
I live in the bay area in california.
ladybugRC
458
Aug 21, 2020 10:41 AM
stanz
Oct 30, 2015 10:33 AM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
Sep 21, 2015 04:55 AM
gyroscope7
Sep 13, 2015 05:15 AM
